First Micro Build - 3" Jappy
Thought I'd make a list and post a couple pics of my first micro build, the 3" Armattan Japalura.  I'll just say that this frame is a tank!  I'm sure there's a lot better frames out there if racing's the name of your game, but if you're into freestyle and proximity, I don't think you can beat the Jap.  And although it is pretty beefy, with the elimination of some screws (16 to be exact!) and the use of micro components, it comes in at an all-up weight of 243 grams with the 4S 650 mah lipo.  I'm still playing with the rates and filters but with basically default BF 3.1.7 default settings, this little guy is a total blast to fly and really solid on basic flips and rolls, with no overshooting or compensation at all.  If you compare the figures, it doesn't have near the power to weight ratio as a typical 5" racer, but I guess because of it's diminutive stature, it gives you the illusion of being terrifyingly fast hahaha.  Here's a list of parts I used.
iForce iF1407 3500KV motors
Micro Lux V2 F4 flight controller
Lumenier 12A 4 in 1 ESCs
ImmersionRC Tramp HV vtx
TBS Triumph stubby antenna
CM650 FPV camera
Radiolink R6DSM rx
Tattu 4S 650/850/1050 75C lipos
RotorX 3040T props
XT30 connector
[Image: FNFH7cYl.jpg]
[Image: QpwTjM5l.jpg]
[Image: U86UzNAl.jpg]
[Image: gyz2tlil.jpg]
[-] The following 7 users Like RENOV8R's post:
  • Drone0fPrey, kaitylynn, unseen, jimbo_wa, Oscar, KonradS, sloscotty
Very nice RENOV8R!! Beastie! Thumbs Up
  AOS 3" Toothpick build SeismicCWave 34 666 38 minutes ago
Last Post: SeismicCWave
  Meteor65 pro walksnail build, 24g. ph2t 0 46 6 hours ago
Last Post: ph2t
  Build BetaFPV Meteor65 Pro 1S Build brettbrandon 9 236 6 hours ago
Last Post: ph2t
  CLI Dump for HGLRC Drashark 1S 1.6inch Micro Quad Oscar 1 638 23-Apr-2024, 08:08 PM
Last Post: segler999
  Build Meteor75 Build (Revision 4) :) Pathfinder075 9 623 14-Apr-2024, 03:28 AM
