10-Mar-2019, 08:48 PM
A couple of weekends ago we had unusual but beautiful February weather here in the UK (16°C, 60°F), and with the wife and daughter away visiting the in-laws, I took the rare opportunity to be able to just disappear for 3 hours and do some flying Other than a bit of time on simulators over the winter period, this was the first time I'd flown my quad in 4 months, it was only the 4th time I'd ever flown FPV, and it was my first time ever flying a real quad in Acro Mode. Using the sims had given me enough confidence with stick co-ordination to actually try Acro Mode in real life, however I did wimp out of full rate mode and instead opted to start off gently using Acro Trainer Mode
The one mistake I did make was that I forgot to bring an OTG cable with me so I could make any adjustments in the field if I needed to. It wasn't a showstopper, but the biggest limiting factor was that I'd configured my quad for Acro Trainer Mode and had neglected to check what the default maximum tilt angle was. It turned out to be only 20 degrees which was way too shallow, especially when doing quick 180 yaws because there wasn't really any ability to get enough forward bite to pull out of a backward drift after doing a 180, which resulted in a few backward crashes or near misses. However, I wasn't going to waste time going back home for a cable, so I just decided to try and make do with the situation.
The places I'd previously been flying at turned out out to be less than suitable either because of power lines, dense tree lines (too precarious for a beginner), or a million dog walkers deciding to turn up in force at the same time as me. So at the end of last year I scouted out the area for some new places to fly. A lot of the area around here is private farmland so while there are some vast areas of open fields and woodland, it is mostly all off-limits and fenced/gated off, and I don't want particularly want to be had for trespassing by an angry farmer with a shotgun I did however find a couple of other potential candidates so I decided to give one a try.
This particular place has a huge open field with a couple of rugby posts, some pushed together football (soccer) goals, a few small trees at the far end, and most importantly soft ground, so it's an ideal training location for a beginner. The area is around ~200m x 300m, so plenty of room without having to worry too much about going outside the boundaries The only downside is that while publicly accessible with no hard boundary or fencing, it's actually privately owned land which is attached to a science campus, and there's a sign erected nearby stating that use of the land was only for the members of the science campus recreation association. So there was a risk that security guards could turn up and move me on, but thankfully that didn't happen on this occasion. I guess we'll see how long I can use this place for in future without getting pounced on and kicked out.
I had 10 fully charged 1550mAh LiPos with me so I was all set for a nice long session I was there for almost 3 hours with 2 of those taken up with actual flying, or walking 200m to retrieve a downed craft and then 200m back again The place was completely desolate of people and in those 3 hours only two dog walkers appeared together for a period of about 10 minutes, and then they left again. So I didn't have to worry about people and dogs, or the fact I didn't have a spotter with me
I had a few near misses with trees and posts but in those 2 hours I only actually crashed 3 times onto the deck, 2 of which needed manual retrieval, so I didn't think that was too bad going, although there was obviously no risky acrobatics involved this time due to the Acro Trainer Mode.
Unfortunately the battery on my Hawkeye Firefly died before I started to show some improvement at flying, so most of the better flying footage I came back with was poor quality goggle DVR only. There are a lot of science research tech companies in the area and as you can also see in my footage, there's a large satellite dish in the background. So I wasn't sure what to expect as far as RF interference goes on both the 2.4GHz and 5.8GHz frequencies, but with my VTX only set to 25mw it seemed to do well enough, and I didn't seem to have any noticeable issues with the RSSI between my X9D+ transmitter and the R-XSR receiver. After last years unexpected failsafe, my confidence in the R-XSR during this flying session has certainly increased again.
The flight videos below are fairly mundane compared to other ones on here from seasoned expert pilots but they form a record of my (slow) progress for my own purposes, so I decided to post them here anyway In the first video I managed to do some lowish ground flying, some rugby post fly-throughs without hitting anything, and a reasonably controlled(ish) circling around one of the rugby posts a few times. Unfortunately I wasn't quite so lucky in the second video (which was actually shot a few packs prior to the first video)
Now that I've started to build up a bit of muscle memory, next time I may try to be a bit braver and go full Acro Mode I'm still holding back a little knowing that I only currently have one proper sized flyable quad and I don't really want it being out of action for weeks on the repair bench, so I definitely need to build some more quads...purely for backup purposes of course
Unfortunately the weather has turned sour again so I don't know when the next window of opportunity will arise to go back there. In the meantime I guess I will just be stuck on the sims
Event time positions for the video below --> Low Ground Flying: 1:14; Goal Post Fly-Through: 1:36; Tree Scrape: 1:57; Goal Post Fly-Through: 2:12; Goal Post Fly-Through: 2:30; Goal Post Fly-Around: 2:50; Low Ground Flying: 3:42; Goal Post Fly-Through: 3:54; Bumpy Landing: 4:36
And the following video should hopefully get me an IntoFPV "Pole Dancer" achievement badge which I'll apply for later
