16-May-2024, 06:34 PM
Does the GPS module power up with just a USB cable connected? If it does then do that until you have a 3D fix and then power up the quad with a LiPo and see if the lock is retained. If it is then that's one option you have before each flight.
I have a similar issue on one of my quads where it will only get a 3D fix if first powered from USB (I use an Android phone to do that with the Betaflight Android app running so I can visually monitor the satellite acquisition status in the GPS tab), and once it has a 3D fix and plenty of satellites I then power it up with a LiPo after which the 3D fix and acquired satellites are retained, so I then take off and go flying.
If yours does the same then you can use that same pre-flight procedure, or look at getting a VIFLY GPS-mate which helps to do something similar.
Other options are one or more of the following:
- Twist the wires running between the GPS module and the FC.
- Wrap the wires running between the GPS module and the FC in insulated copper tape (which needs to be grounded at one end).
- Mount the GPS module on top of the battery strap.
- Design and 3D print a mount which hangs the GPS module off the back of the quad so it's as far away from the carbon frame and any electronics in the quad as possible.
