10-Jun-2018, 07:13 AM
Could I get some thoughts on which component is likely to go bad first when you apply too much voltage to a 5v flight controller?
After killing a FC (SP Racing F3 V1 wont power up anymore with battery or USB), I discovered that the "5v" PDB pad actually delivered closer to 11 volts! I should have checked it with my meter before I assumed it was correct...lesson learned.
I'm wondering if I might salvage the FC by replacing some specific (if tiny) part...keep it or toss it?
