Threads: 26
Likes Received: 1 in 1 posts
Likes Given: 0
0 iNav 5.0
matek 722SE 5.0
Radiomaster 16s Edge 2.7.1
Bat 4S 15.2V (storage) for test
All symbols ready to arm but will not arm because flight controller beeps rapidly and continuously when battery connected. Calibrated Tx, double checked all that I know about but could not find problem. Wish I spent more time flying
Threads: 38
Likes Given: 430
118 If this is an analog FPV system build then turn on warnings in the OSD and it should report whats stopping the quad from arming.
Does it have a GPS module? Do you have enough satellites for a GPS fix?
What flight mode are you flying? Angle mode or horizon mode will require the accelerometer to be calibrated.
Go into the CLI and type status and report back what it says.
Also connect to INAV and see if the Configurator lists any warnings.
Threads: 26
Likes Given: 0
0 set battery_capacity = 3300
set battery_capacity_warning = 3300
set failsafe_throttle = 1200
# end the command batch
batch end
# status
System Uptime: 119 seconds
Current Time: 2022-08-10T20:55:10.317+00:00
Voltage: 0.03V (1S battery - NOT PRESENT)
CPU Clock=216MHz, GYRO=MPU6000, ACC=MPU6000, BARO=SPL06, MAG=QMC5883
STM32 system clocks:
SYSCLK = 216 MHz
HCLK = 216 MHz
PCLK1 = 54 MHz
PCLK2 = 108 MHz
Sensor status: GYRO=OK, ACC=OK, MAG=OK, BARO=OK, RANGEFINDER=NONE, OPFLOW=NONE, GPS=OK, IMU2=NONE
SD card: Startup failed
Stack size: 6144, Stack address: 0x20010000, Heap available: 1716
I2C Errors: 1081, config size: 9692, max available config: 16384
ADC channel usage:
BATTERY : configured = ADC 1, used = ADC 1
RSSI : configured = ADC 3, used = none
CURRENT : configured = ADC 2, used = ADC 2
AIRSPEED : configured = ADC 4, used = none
System load: 16, cycle time: 509, PID rate: 1964, RX rate: 49, System rate: 9
Arming disabled flags: NAV RX CLI
VTX: not detected
Looks like multiple problems. I dont understand VTX not detected because it works. It was in angle mode and received nav error?
Havent changed Batt capacity. Usually use cell voltage
GPS fix ok. accelerometer calibrated.
iNAV not posting warnigs
Threads: 38
Likes Given: 430
118 Did you test the arm switch and transmitter sticks on the INAV Configurator Receiver tab? Do you have an arm switch setup in the Models tab?
There are no serious errors with the status command output.
