Threads: 7
Likes Received: 0 in 0 posts
0 So the problem that i have currently is that when i plug in my battery to the drone the lights dont light up and make that sound. Ive just installed and flashed beta flight onto the drone. However when i connect the fc to the computer via micro usb the lights come on. So not sure what the problem is, and dont know if i have broken fc as prior to installing betaflight everything worked just fine.
Threads: 125
Likes Given: 99
388 Your 5V regulator or the schottky diode might be bad.
Threads: 125
Likes Given: 99
388 I work try to get into bootloader mode and reflash the firmware with full chip erase.
Threads: 125
Likes Given: 99
388 There is not a setting that would cause you problem.
Threads: 7
0 So i bought a new fc and i seem to have the same problem no lights come on
Threads: 594
Likes Received: 9,031 in 6,685 posts
Likes Given: 1,428
796 What replacement FC did you buy and how is it wired to the ESC? Can you please post some photos.
