I just put together a new build with Mamba DJI F405 MK2 FC/Stack. Whenever I connect FC to Betaflight it is always defaulting to DFU mode. I flashed firmware but still same, every time I have to go to 'Flash Firmware' option and manually click 'Exis DFU' option to convert to COMM3 port and connect normally. Due to this I cant even arm because the FC is always sitting in DFU bootloader mode when I connect Lipo. Is this due to issue in the boot switch or something can be done in setting?
FC always in DFU |
01-Aug-2021, 09:22 AM This sounds like a stuck boot button. See if you are able to check continuity on that button with a multimeter. 01-Aug-2021, 07:56 PM If this is a brand new board I would put in a support ticket with the manufacturer. They might have encountered this before and know a fix for you, or be able to replace the board with a new one. 01-Aug-2021, 08:16 PM (This post was last modified: 01-Aug-2021, 08:17 PM by rockford007.) Yes it is brand new board as part of a stack, this morning I tested the button with a multimeter for continuity result came as negative, means button not sorted, only showing continuity after pressing button which is expected. Thinking to drop an email to seller. I tried flashing the firmware to latest, everything looks good but still always DFU. 03-May-2022, 12:36 PM @rockford007 Hi did you find what the problem was? I got the same issue with mamba mk2 ? |
DFU Zadig and impulseRC | zomer | 1 | 502 | 09-Aug-2023, 04:23 PM Last Post: voodoo614 | |
CRAZYBEE F4 PRO doe not get to DFU mode | orangu | 8 | 3,680 | 08-Aug-2023, 09:46 PM Last Post: zomer | |
Help Kakute F745 HDV, DFU mode and I2C errors. | Zanna83 | 32 | 4,668 | 07-May-2022, 05:56 AM Last Post: Clones123 | |
cannot enter DFU with a new Omnibus Nano V4 6.1 | finnigan | 5 | 1,052 | 07-Nov-2020, 11:42 PM Last Post: finnigan | |
Bardwell board won’t enter dfu, now solved! | Jakefpv | 0 | 2,156 | 30-Jun-2018, 07:55 AM Last Post: Jakefpv |
