09-Aug-2022, 08:34 AM
Hot on the heels of RC1, the ELRS devs have just released v3.0.0 RC2. Release notes below.
https://github.com/ExpressLRS/ExpressLRS.../3.0.0-RC2
ExpressLRS V3.0.0 Release Candidate 2
Changes since RC1
Changes since RC1
- Rename Lua file name to elrsV3.lua (works with 2.x as well still) #1680
- Display warning message when baud too low for the selected RF mode #1672
- Fix R9MM RX (and any other external EEPROM devices) resetting config on every reboot #1675
- Changes to OTA packet to reduce the chances of accidental connection between V2 and V3 devices. #1673
- Allow button to reset RX config #1681
- Fix missing and unaligned descriptions in hardware.html #1725
- Adjust VBAT scaling for 6ch PWM RX #1724
- HGLRC Hermes TX not working on 3.0 #1716
- mDNS missing product/device name #1710
- Fix difficulty flashing Betaflight passthrough where target name was reporting a number #1708
- IN866 region not working #1706
- Allow CORS through webui #1703
- Allow working with a failed accelerometer #1698
- Adjust AION Nano joystick right value #1696
- Calibrate T-Lite power levels #1692
- Fix software version returned by DeviceInfo when not running a tagged release #1689
- Fix default LED on R9M #1688
- Webui sometimes reporting firmware upload success on failure #1685
- Fix always enabling SX1280 DCDC on all hardware #1683
- UID displayed in webui not always correct #1670
- Antenna pin names standardized across RX and TX #1663
- EU CE Regulatory Domain display text #1740
- Only change RF power when idle, delay disconnected #1734
- Fix 1:2 telem ratio on ESP32 RX #1737
- Only adjust PFD when a new result is available #1743
- Fix BLE/WiFi exit on LUA #1750
- Delay sending of VTX Admin if reconnected quickly #1744
