21-May-2018, 10:39 PM
Hi everyone!
Not sure if this thread would fit better in the beginners section, either way, here goes:
I'm not very good at flying and just broke my last replacement arm of my first one. I really don't want to repair it because it doesn't fly very well and is broken/outdated. Also it's a way bigger frame with 920kv motors and something like 9" props, not at all what I want anymore!
So, for my new build, which I don't want to put a ton of money on, since I will most likely be crashing a lot anyway I'm looking at getting some motors for 5" props.
I've found some 2205 Turnigy motors on hobbyking that are only 6€. My question is, why are they so inexpensive? They're 2300kv, 28g. Max 21A and according to the description can do 800g of thrust using 5045 props. What's the catch? I really don't think I'll be needing the extra 200g of thrust as I've got a lot to learn left before I would even be able to use that extra power.
Also, the description specifies an efficiency of <3.0 g/W. Is that terribly low, meaning I wont be able to fly more than a couple of minutes before I need to change/recharge batteries?
Here are the motors:
https://hobbyking.com/en_us/brushless-mo...kv-cw.html
TL;DR
Can I buy Turnigy motors for 6€ and not expect them to catch fire mid-air?
Thanks a ton for any answers!
TL;DR
