Eachine Wizard twitches in air
Eachine Wizard running the most up to date Betaflight and Dshot150, and ESC's with up to date firmware with this problem when I fly:
I've tried changing the props, I've made sure everything is tightened down properly, I'm just stumped. Flysky i6x, sbus.
Bueller?
I suggest disabling DShot and then calibrating the escs to see if it still happens. If it does, then I'd check motor to esc solder joints.
The same issue on my built.
http://intofpv.com/t-first-brushless-bui...rs-problem
To me it looks like the typical strong yaw twitches which come from gyro noise overload. Possible causes are electrical noise (add low-esr caps), physical noise (balance motors and/or props, and/or soft-mount FC) - or simply a bad/broken gyro (replace FC).
Maybe a faulty bearing? I have noticed a bearing not perfectly smooth (not blocked but noisy )...
(04-Mar-2017, 05:15 PM)lorentz Wrote: Maybe a faulty bearing? I have noticed a bearing not perfectly smooth (not blocked but noisy )...
Yes of course this can be very bad. Also check for excessive play between shaft and bearings.
  Dual antenna of OG Air Unit combined into one Fpv_Snidde 2 87 21-Apr-2024, 09:19 AM
Last Post: Fpv_Snidde
  No RC data or signal in Goggles 2 on O3 Air drones nicorossi 3 252 10-Mar-2024, 10:45 AM
Last Post: nicorossi
  Mid Air Radio Failure on a quad with RTH Pathfinder075 9 189 26-Feb-2024, 10:26 AM
  After 1-2 minutues of flight, drone flips over in air doublebubble 22 793 16-Feb-2024, 11:32 PM
Last Post: mstc
  Eachine V100 vs Fatshark HDO V1 miklere 15 676 13-Jan-2024, 12:59 PM
