10-Apr-2019, 10:53 PM
Hello!
not sure if this is the right place but it seems as though.
So we all know of the stupid little toggle button to control the pro58 RX, how annoying they are to use and how they always break.
Now i've seen a few mods where people do some jank soldering to mount 3 momentary push buttons, but between myself and my mates (and my fiancee) we have almost 10 of these. So I devised a solution
This is a very simple PCB I designed and it takes 3 6x6mm surface mount push buttons, the plan is to run wires from the pads at the bottom of the PCB to the pads where the old toggle switch originally connected to. Then you can either have long wires to use it as a remote (for OSD) but I plan on double sided taping it to the top of my goggles infront (or behind) the channel button. That way they are easily pressed.
The PCB's are on order currently so I will update the thread once I get them and do some tests.
If i was to sell these for a few $$ a piece with wires and buttons installed would anyone be interested in it?
Dave
Dave
