15-Mar-2019, 05:38 PM (This post was last modified: 15-Mar-2019, 09:07 PM by Volitant_Soul.)
Hey guys,
I've recently swapped our my XSR for the R9MM and have not been able to get it to connect to the receiver. I downloaded the FW from Frsky 181228 and updated my Rx and my understanding is there's a couple of ways of getting this to work. I went with 4 wires SBUS out from the R9MM to the SBUS pad on the FC, F.Port/S.Port connected to RX3 which is TX3(Frsky mislabeled the pinouts), ground, and pos(5v) rail. If I can go with just 3 wires please tell me how I can accomplish this.
I have attached a photo of my FC and R9MM and a picture of the DYS F4 Pro pinout for reference.
**Update** I tried going the F.Port route by using 3 wires pos, ground, and S.Port/F.Port on TX1(Uart1) and enabling soft serial assigned to 11 A09. After I save Serial Rx to soft serial in the ports tab and go to change the receiver mode to serial based receiver > Frsky F.port and try to save it does not save the settings. I tried several times and reinstalled BF 3.5.5. As a matter of fact BF config freezes and I have to hit disconnect > reconnect.
First of all, you can't use F. Port protocol on softserial. Secondly, you can't use F. Port if you didn't use F. Port firmware for receiver. Pick either 4 wires or 3 wires and I will try to help.
You should also update the R9M module firmware. Update your OpenTX.
(15-Mar-2019, 11:25 PM)voodoo614 Wrote: First of all, you can't use F. Port protocol on softserial. Secondly, you can't use F. Port if you didn't use F. Port firmware for receiver. Pick either 4 wires or 3 wires and I will try to help.
I have the R9M module updated to the newest FW and successfully binded a couple of other quads that got the R9MM upgrade and setup in BF. Please explain how I can do this both ways. I will go with the 3 wires(F.Port)? as I've heard it being better than using SBUS.
Do I have the correct target BF FW OMNIBUSF4SD? R9M Module FCC 181228 R9MM FCC 181228
You get the idea. Or you can goto to port tab and toggle the serial rx for the correct port. So yes, you have to change it in CLI or port tab for the correct UART. All other CLI commands stay the same.
So then I should have in ports tab > Uart1 to serial Rx on and in the receiver mode to serial based (SBUS) > F.Port then I type the CLI commands with no soft serial, correct?
Okay so I reflashed FW to get rid of any remap and have pos, ground, and inverted S.Port wired from the R9MM to the pos, ground, and inverted S.Port going to Uart-Tx(Uart1) on the DYS F4. I typed the CLI commands and it's not working for me.
Here's my dump
# version # Betaflight / OMNIBUSF4SD (OBSD) 3.5.5 Jan 15 2019 / 13:30:51 (8a09989f7) MSP API: 1.40
# serial serial 20 1 115200 57600 0 115200 serial 0 0 115200 57600 0 115200 serial 2 64 115200 57600 0 115200 serial 5 0 115200 57600 0 115200
# led led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0
# master set align_gyro = DEFAULT set gyro_hardware_lpf = NORMAL set gyro_32khz_hardware_lpf = NORMAL set gyro_sync_denom = 1 set gyro_lowpass_type = PT1 set gyro_lowpass_hz = 100 set gyro_lowpass2_type = PT1 set gyro_lowpass2_hz = 300 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = ON set yaw_spin_threshold = 1950 set gyro_use_32khz = OFF set dyn_notch_quality = 70 set dyn_notch_width_percent = 50 set align_acc = DEFAULT set acc_hardware = AUTO set acc_lpf_hz = 10 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = 0,0,0 set align_mag = DEFAULT set mag_bustype = I2C set mag_i2c_device = 2 set mag_i2c_address = 0 set mag_spi_device = 0 set mag_hardware = AUTO set mag_declination = 0 set mag_calibration = 0,0,0 set baro_bustype = SPI set baro_spi_device = 3 set baro_i2c_device = 0 set baro_i2c_address = 0 set baro_hardware = AUTO set baro_tab_size = 21 set baro_noise_lpf = 600 set baro_cf_vel = 985 set baro_cf_alt = 965 set mid_rc = 1500 set min_check = 1050 set max_check = 1900 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 0 set rssi_invert = OFF set rc_interp = AUTO set rc_interp_ch = RPYT set rc_interp_int = 19 set rc_smoothing_type = INTERPOLATION set rc_smoothing_input_hz = 0 set rc_smoothing_derivative_hz = 0 set rc_smoothing_debug_axis = ROLL set rc_smoothing_input_type = BIQUAD set rc_smoothing_derivative_type = BIQUAD set fpv_mix_degrees = 0 set max_aux_channels = 14 set serialrx_provider = FPORT set serialrx_inverted = OFF set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = ON set airmode_start_throttle_percent = 32 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = ON set adc_device = 2 set input_filtering_mode = OFF set blackbox_p_ratio = 32 set blackbox_device = SDCARD set blackbox_record_acc = ON set blackbox_mode = NORMAL set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 350 set dshot_burst = ON set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 14 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 4 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 0 set gimbal_mode = NORMAL set bat_capacity = 0 set vbat_max_cell_voltage = 43 set vbat_full_cell_voltage = 41 set vbat_min_cell_voltage = 33 set vbat_warning_cell_voltage = 35 set vbat_hysteresis = 1 set current_meter = ADC set battery_meter = ADC set vbat_detect_cell_voltage = 30 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 400 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = OFF set crashflip_motor_percent = 0 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lowpass_hz = 0 set tri_unarmed_servo = ON set channel_forwarding_start = 4 set reboot_character = 82 set serial_update_rate_hz = 100 set accxy_deadband = 40 set accz_deadband = 40 set acc_unarmedcal = ON set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 25 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set gps_provider = NMEA set gps_sbas_mode = AUTO set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_use_galileo = OFF set gps_rescue_angle = 32 set gps_rescue_initial_alt = 50 set gps_rescue_descent_dist = 200 set gps_rescue_ground_speed = 2000 set gps_rescue_throttle_p = 150 set gps_rescue_throttle_i = 20 set gps_rescue_throttle_d = 50 set gps_rescue_velocity_p = 80 set gps_rescue_velocity_i = 20 set gps_rescue_velocity_d = 15 set gps_rescue_yaw_p = 40 set gps_rescue_throttle_min = 1200 set gps_rescue_throttle_max = 1600 set gps_rescue_throttle_hover = 1280 set gps_rescue_sanity_checks = RESCUE_SANITY_ON set gps_rescue_min_sats = 8 set deadband = 0 set yaw_deadband = 0 set yaw_control_reversed = OFF set pid_process_denom = 4 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 25 set tlm_inverted = OFF set tlm_halfduplex = ON set frsky_default_lat = 0 set frsky_default_long = 0 set frsky_gps_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = OFF set ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0 set smartport_use_extra_sensors = OFF set ledstrip_visual_beeper = OFF set ledstrip_grb_rgb = GRB set sdcard_dma = OFF set osd_units = METRIC set osd_warn_arming_disable = ON set osd_warn_batt_not_full = ON set osd_warn_batt_warning = ON set osd_warn_batt_critical = ON set osd_warn_visual_beeper = ON set osd_warn_crash_flip = ON set osd_warn_esc_fail = ON set osd_warn_core_temp = ON set osd_rssi_alarm = 20 set osd_cap_alarm = 2200 set osd_alt_alarm = 100 set osd_esc_temp_alarm = -128 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 234 set osd_rssi_pos = 234 set osd_tim_1_pos = 234 set osd_tim_2_pos = 234 set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 234 set osd_anti_gravity_pos = 234 set osd_g_force_pos = 234 set osd_throttle_pos = 234 set osd_vtx_channel_pos = 234 set osd_crosshairs_pos = 205 set osd_ah_sbar_pos = 206 set osd_ah_pos = 78 set osd_current_pos = 234 set osd_mah_drawn_pos = 234 set osd_craft_name_pos = 234 set osd_gps_speed_pos = 234 set osd_gps_lon_pos = 234 set osd_gps_lat_pos = 234 set osd_gps_sats_pos = 234 set osd_home_dir_pos = 234 set osd_home_dist_pos = 234 set osd_compass_bar_pos = 234 set osd_altitude_pos = 234 set osd_pid_roll_pos = 234 set osd_pid_pitch_pos = 234 set osd_pid_yaw_pos = 234 set osd_debug_pos = 234 set osd_power_pos = 234 set osd_pidrate_profile_pos = 234 set osd_warnings_pos = 2377 set osd_avg_cell_voltage_pos = 234 set osd_pit_ang_pos = 234 set osd_rol_ang_pos = 234 set osd_battery_usage_pos = 234 set osd_disarmed_pos = 234 set osd_nheading_pos = 234 set osd_nvario_pos = 234 set osd_esc_tmp_pos = 234 set osd_esc_rpm_pos = 234 set osd_rtc_date_time_pos = 234 set osd_adjustment_range_pos = 234 set osd_core_temp_pos = 234 set osd_stat_rtc_date_time = OFF set osd_stat_tim_1 = OFF set osd_stat_tim_2 = ON set osd_stat_max_spd = ON set osd_stat_max_dist = OFF set osd_stat_min_batt = ON set osd_stat_endbatt = OFF set osd_stat_battery = OFF set osd_stat_min_rssi = ON set osd_stat_max_curr = ON set osd_stat_used_mah = ON set osd_stat_max_alt = OFF set osd_stat_bbox = ON set osd_stat_bb_no = ON set task_statistics = ON set debug_mode = NONE set rate_6pos_switch = OFF set cpu_overclock = OFF set pwr_on_arm_grace = 5 set vtx_band = 4 set vtx_channel = 1 set vtx_power = 1 set vtx_low_power_disarm = OFF set vtx_freq = 5740 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON set vcd_video_system = AUTO set vcd_h_offset = 0 set vcd_v_offset = 0 set max7456_clock = DEFAULT set max7456_spi_bus = 3 set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 set displayport_max7456_inv = OFF set displayport_max7456_blk = 0 set displayport_max7456_wht = 2 set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set led_inversion = 0 set dashboard_i2c_bus = 2 set dashboard_i2c_addr = 60 set camera_control_mode = HARDWARE_PWM set camera_control_ref_voltage = 330 set camera_control_key_delay = 180 set camera_control_internal_resistance = 470 set camera_control_inverted = OFF set rangefinder_hardware = NONE set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set usb_msc_pin_pullup = OFF set flash_spi_bus = 2 set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000
# profile profile 0
set dterm_lowpass_type = PT1 set dterm_lowpass_hz = 100 set dterm_lowpass2_hz = 200 set dterm_notch_hz = 0 set dterm_notch_cutoff = 160 set vbat_pid_gain = OFF set pid_at_min_throttle = ON set anti_gravity_mode = SMOOTH set anti_gravity_threshold = 250 set anti_gravity_gain = 5000 set feedforward_transition = 0 set acc_limit_yaw = 100 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = ON set smart_feedforward = OFF set iterm_relax = OFF set iterm_relax_type = GYRO set iterm_relax_cutoff = 11 set iterm_windup = 40 set iterm_limit = 150 set pidsum_limit = 500 set pidsum_limit_yaw = 400 set yaw_lowpass_hz = 0 set throttle_boost = 5 set throttle_boost_cutoff = 15 set acro_trainer_angle_limit = 20 set acro_trainer_lookahead_ms = 50 set acro_trainer_debug_axis = ROLL set acro_trainer_gain = 75 set p_pitch = 50 set i_pitch = 50 set d_pitch = 27 set f_pitch = 60 set p_roll = 46 set i_roll = 45 set d_roll = 25 set f_roll = 60 set p_yaw = 65 set i_yaw = 45 set d_yaw = 0 set f_yaw = 60 set p_level = 50 set i_level = 50 set d_level = 75 set level_limit = 55 set horizon_tilt_effect = 75 set horizon_tilt_expert_mode = OFF set abs_control_gain = 0 set abs_control_limit = 90 set abs_control_error_limit = 20
# rateprofile rateprofile 0
set thr_mid = 50 set thr_expo = 0 set rates_type = BETAFLIGHT set roll_rc_rate = 100 set pitch_rc_rate = 100 set yaw_rc_rate = 100 set roll_expo = 0 set pitch_expo = 0 set yaw_expo = 0 set roll_srate = 70 set pitch_srate = 70 set yaw_srate = 70 set tpa_rate = 10 set tpa_breakpoint = 1650 set throttle_limit_type = OFF set throttle_limit_percent = 100
16-Mar-2019, 05:42 AM (This post was last modified: 16-Mar-2019, 06:18 AM by Volitant_Soul.)
I set UART1 to serial rx in the PORT tab and turned on telemetry saved and it's not working. I have V_IN going to 5v, ground to ground and inverted S.Port connected to UART1. Can you show an illustration of how everything should be wired up?
