21-Aug-2020, 04:45 AM
I crashed my Rooster 5" & destroyed the camera lens - a rock managed to fit between the titanium frames. Anyway, I decided to cram a Runcam Split 3 Micro into this tight frame plus a Matek loud beeper. The only way to get the Runcam board into the stack was by making a custom low-profile adapter plate. This worked out well giving plenty of space for the battery strap. The beeper fit nicely onto the backside of the camera. As pointed out somewhere you do need a small cap on the darn thing between B- and ground.
So anyway during the rebuild there were plenty of screws everywhere including some very small 2 mm ones that hold the camera. Between the new camera screws and the old ones I had plenty of leftovers hanging around.
After a couple of test flights things appeared good so I turned the recorder and started to gets serious when all of a sudden my FPV screen freezes. So I was lucky & just throttled down making a good landing in the blind.
So what the hell. There are some people complaining about this happening with Runcam so I checked everything out and things appear solid. So back to some test flights and while flying LOS weird things start happening - oscillations & motor noise. Now one of the motor is seriously binding & destroying itself.
So long story short, one of those 2 mm camera screws got sucked into the motor because you know those magnets in there are pretty damn strong. You can see that both the windings and magnets were pretty mangled up. So I'm theorizing I had some pretty serious current spikes going on that caused the the FPV feed to freeze up.
After I get a new motor installed I'll be able to test my theory but in the mean time watch out for metal things getting into your motor's - especially when they're off the arms!
