Drone turns on and binds to transmitter, but motors doesn't spin.
I connected the battery, it does the beeping sound and stuff, but the motors doesn't spin at all when I put throttle to it.
I tried connecting my setup to BLHeli but it gets stuck at "Please connect ESC and power up".
Not sure what Im doing wrong here as I am a complete noob.
Im using a Mini F4 flytower from Siglomax.
First we need some more specifics...
  1. Do the motors spin up if you try to do so in the Motors tab of Betaflight?
  2. If yest to (1) then I assume you mean they don't spin up when you use the transmitter, so has the transmitter been successfully bound to the receiver?
There are a load more question to ask regarding wiring and Betaflight configuration but lets start off the above two questions first so we know if we are dealing with a communication problem between the flight controller and ESCs, or a communication problem between the transmitter and receiver and/or flight controller.
(16-Jun-2019, 02:47 PM)SnowLeopardFPV Wrote: First we need some more specifics...
Thank you sooooo much for responding.
1. I havent been able to go into Betaflight at all cuz of it being stuck to the "Please connect ESC" message. BLHeli detects my device but cannot seem to see the ESCs.
2. I already did the binding and I can tell that it bound properly as it is showing a signal indicator in my Taranis and the drone has green light already.
Im using a mini F4 tower so I am very confused on how can this happen. The ESCs are built-in the board and the power is on for the board at the top. The VTX and the receiver is lighting up and the opening sound can be heard.
That "Please connect ESC" message is something that comes from BLHeli. Don't worry about that for now. It's probably because you're using the wrong version of BLHeli (i.e. BLHeLi instead of BLHeli32). We can look at that later. The first thing will be to see what your Betaflight settings are and if your wiring is correct.
Are you able to connect Betaflight Configurator to the flight controller? Please do that and then run both the "dump" and "diff all" commands in the CLI tab then copy/paste the results back here.
Please also post photos clearly showing the wiring between your receiver and flight controller.
It would also be helpful to know what receiver and transmitter you are using.
(16-Jun-2019, 04:17 PM)SnowLeopardFPV Wrote: That "Please connect ESC" message is something that comes from BLHeli. Don't worry about that for now. It's probably because you're using the wrong version of BLHeli (i.e. BLHeLi instead of BLHeli32). We can look at that later. The first thing will be to see what your Betaflight settings are and if your wiring is correct.
WHOAH. I DID NOT KNOW ABOUT THIS TOOL!!!
I just installed it and tried doing stuff in the motor tab and it worked! Looks like the motors are fine.
Here's the dump CLI output:
# dump
# Betaflight / OMNIBUSF4 3.1.7 Apr  3 2017 / 22:14:59 (e1c4b5c)
# name
name -
# resources
resource BEEPER 1 B04
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 A03
resource MOTOR 4 A02
resource MOTOR 5 A01
resource MOTOR 6 A08
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource MOTOR 9 NONE
resource MOTOR 10 NONE
resource MOTOR 11 NONE
resource MOTOR 12 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 B14
resource PWM 1 B14
resource PWM 2 B15
resource PWM 3 C06
resource PWM 4 C07
resource PWM 5 C08
resource PWM 6 C09
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A01
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 NONE
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 NONE
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
# mixer
mixer QUADX
# servo
# servo mix
smix reset
feature -VBAT
feature -FAILSAFE
feature -SONAR
feature -CURRENT_METER
feature -OSD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature -SDCARD
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -FEATURE_ANTI_GRAVITY
feature VBAT
feature RX_SERIAL
feature FAILSAFE
feature OSD
feature BLACKBOX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
serial 5 64 115200 57600 0 115200
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 1 0 900 2100
aux 1 0 0 900 900
aux 2 0 0 900 900
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set task_statistics = ON
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set rssi_invert = OFF
set fpv_mix_degrees = 0
set max_aux_channels = 14
set debug_mode = NONE
set min_throttle = 1070
set max_throttle = 2000
set digital_idle_percent =  4.500
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set disarm_kill_switch = ON
set small_angle = 25
set fixedwing_althold_dir = 1
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set beeper_inversion = ON
set beeper_od = OFF
set serialrx_provider = SBUS
set serialrx_halfduplex = OFF
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autorst = 1
set tlm_switch = OFF
set tlm_inversion = ON
set sport_halfduplex = ON
set frsky_default_lat =  0.000
set frsky_default_long =  0.000
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set ibus_report_cell_voltage = OFF
set bat_capacity = 0
set vbat_scale = 110
set vbat_hysteresis = 1
set ibat_scale = 400
set ibat_offset = 0
set mwii_ibat_output = OFF
set current_meter_type = ADC
set battery_meter_type = ADC
set bat_detect_thresh = 55
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_yaw = 0
set gyro_lpf = OFF
set gyro_sync_denom = 1
set gyro_isr_update = OFF
set gyro_use_32khz = OFF
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 400
set gyro_notch1_cut = 300
set gyro_notch2_hz = 200
set gyro_notch2_cut = 100
set moron_threshold = 48
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set thr_corr_value = 0
set thr_corr_angle = 800
set yaw_control_direction = 1
set yaw_motor_direction = 1
set servo_center_pulse = 1500
set tri_unarmed_servo = ON
set servo_lowpass_hz = 400
set servo_lowpass = OFF
set servo_pwm_rate = 50
set gimbal_mode = NORMAL
set airmode_start_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set acc_hardware = AUTO
set acc_lpf_hz = 10
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf =  0.600
set baro_cf_vel =  0.985
set baro_cf_alt =  0.965
set baro_hardware = NONE
set mag_hardware = NONE
set mag_declination = 0
set pid_process_denom = 4
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set osd_units = IMPERIAL
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_time_alarm = 10
set osd_alt_alarm = 100
set osd_vbat_pos = 2060
set osd_rssi_pos = 22
set osd_flytimer_pos = 2454
set osd_ontimer_pos = 2422
set osd_flymode_pos = 2412
set osd_throttle_pos = 129
set osd_vtx_channel_pos = 200
set osd_crosshairs = 0
set osd_horizon_pos = 2248
set osd_current_pos = 97
set osd_mah_drawn_pos = 111
set osd_craft_name_pos = 396
set osd_gps_speed_pos = 66
set osd_gps_sats_pos = 386
set osd_altitude_pos = 161
set osd_pid_roll_pos = 322
set osd_pid_pitch_pos = 354
set osd_pid_yaw_pos = 386
set osd_power_pos = 47
set osd_pidrate_profile_pos = 418
set osd_battery_warning_pos = 200
set vcd_video_system = 0
set vcd_h_offset = 0
set vcd_v_offset = 0
# profile
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set pidsum_limit =  0.500
set pidsum_limit_yaw =  0.500
set d_lowpass_type = BIQUAD
set d_lowpass = 100
set d_notch_hz = 260
set d_notch_cut = 160
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_thresh = 350
set anti_gravity_gain =  3.000
set setpoint_relax_ratio = 100
set d_setpoint_weight = 60
set yaw_accel_limit =  10.000
set accel_limit =  0.000
set iterm_windup = 50
set yaw_lowpass = 0
set p_pitch = 58
set i_pitch = 50
set d_pitch = 35
set p_roll = 44
set i_roll = 40
set d_roll = 30
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_sensitivity = 55
set level_limit = 55
# rateprofile
set rc_rate = 100
set rc_rate_yaw = 100
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 10
set tpa_breakpoint = 1650
And the diff all:
diff all
defaults
# name
# resources
# mixer
# servo
# servo mix
# beeper
# map
# color
# mode_color
aux 0 1 0 900 2100
# adjrange
# rxrange
# rxfail
# master
# profile
# rateprofile
# rateprofile
rateprofile 1
# rateprofile
rateprofile 2
# profile
profile 1
# rateprofile
# rateprofile
rateprofile 1
# rateprofile
rateprofile 2
# profile
profile 2
# rateprofile
# rateprofile
rateprofile 1
# rateprofile
rateprofile 2
# save configuration
save
Attached is the photo of my FC with the wires leading to the Receiver.
Im using the FrSky 2.4 GHz ACCST R-XSR receiver and FrSky Taranis X-lite controller.
No photos were attached to the last post. Please can you try again. See this guide if you're not sure how to do it.
You currently have two UARTs set up for "Serial RX" which will cause a conflict. Once you have provided a photo of the wiring we can tell you which one needs to be set for that.
(16-Jun-2019, 06:50 PM)SnowLeopardFPV Wrote: No photos were attached to the last post. Please can you try again. See this guide if you're not sure how to do it.
Sorry about that. Here are the photos.
[Image: eZ4YCoJl.jpg]
[Image: bMLH8mYl.jpg]
OK, the SBUS OUT connection on your R-XSR is connected to the SBUS pad on your flight controller which is on UART1.
https://www.banggood.com/Micro-20x20mm-B...32495.html
[Image: 254ef345-24cd-420b-aee8-ef0b6c4a8f36.jpg]
Please run the following commands in the CLI then reconnect Betaflight Configurator to the flight controller, switch to the Receiver tab, and see if the bars are moving when you move your sticks.
save
(17-Jun-2019, 12:34 AM)SnowLeopardFPV Wrote: OK, the SBUS OUT connection on your R-XSR is connected to the SBUS pad on your flight controller which is on UART1.
save
I ran the command and reconnected but there's no movement in the bars in the Receiver Tab.
Have you bound your X-Lite transmitter to the R-XSR receiver? (i.e. when you power on the R-XSR and then switch on your X-Lite, does the red LED on the R-XSR go out and the green LED come on instead?).
Also, do you have a blue LED light on your R-XSR? Your photos only show a red light. No blue LED means that the receiver is in CPPM mode and if that is the case then you need to switch it to SBUS mode. To do that, hold the F/S button down for 4 seconds. The blue LED should then flash 3 times and remain on to indicate that the receiver is in SBUS mode.
(17-Jun-2019, 01:24 AM)SnowLeopardFPV Wrote: Have you bound your X-Lite transmitter to the R-XSR receiver? (i.e. when you power on the R-XSR and then switch on your X-Lite, does the red LED on the R-XSR go out and the green LED come on instead?).
Yes it does go from blinking Red to Green.
Im not sure if there's a blue light as I've only seen Red and Green. I will try again later. I had to go to work.
Thanks a lot man!! I was ready to throw my drone outside. lol
I'll let you know what happens later.
So I just bound the Transmitter and the receiver again and it now looks like this:
[Image: C6owjbZl.jpg]
And the Transmitter has that signal bar:
[Image: x4PhFACl.jpg]
I can now also see the Betaflight Receiver tab moving when I move the sticks.
OK, that's great news. So I guess everything is now working as you expect it to. At least the resolution turned out to be something simple Smile
Just one other thing to note is that you're on quite an old version of Betaflight so I would consider upgrading to at least the latest version of Betaflight 3.x (which is 3.5.7), or if you're feeling brave, the very latest version of Betaflight which is currently 4.0.3.
Before you flash any new firmware, just be sure to run the "diff all" command in the CLI first and save the output to a text file. After flashing you can then just copy/paste those settings back into the CLI and apply them. Any custom settings you currently have are all compatible with Betaflight 4.0.3 so there are no translations to be done.
(17-Jun-2019, 10:49 PM)SnowLeopardFPV Wrote: OK, that's great news. So I guess everything is now working as you expect it to. At least the resolution turned out to be something simple Smile
It didn't work at first because the sticks are configured in betaflight differently, the throttle is in the right and the pitch and roll is in the left. I just selected another option from the dropdown and then it worked.
Thanks a lot for the help man! I almost gave up and just return the board HAHAHAHHA.
I would try to do the flashing later. Ill enjoy it while it can fly for now HAHHAHAHA. Havent actually gotten to fly it yet as I cannot fit the receiver and the VTX inside the frame :|
I should've gone for a bigger build as a beginner.
  Drone accelerometer issues Mohawk219 4 530 13-Jun-2024, 08:22 PM
Last Post: [email protected]
  Drone throttling upwards aggressively when yawing Jueb 19 632 11-Jun-2024, 08:25 PM
Last Post: Jueb
  Receiver doesn't show up in Betaflight asdvcd 3 182 10-Jun-2024, 11:22 PM
Last Post: asdvcd
  drone problem Filip371 1 136 08-Jun-2024, 08:35 PM
  GPS Rescue Failed, Drone lost cycloholic 12 342 08-Jun-2024, 12:44 PM
