Introduction
It is hard to list the vast number of configurations capable of sustaining flight... and in my opinion the Dragonfly is best: being quite, agile and efficient, its performance is hard to beat [or match, for that matter].
I've alway wanted to -someday- design my own Dragonfly inspired MAV, but was quickly discourage due to the nearly infinite number of possible configurations, and in turn, the project was delayed.
After some time, Festo unveiled there BionicOpter, I liked there design, but 9DOFs (Degrees Of Freedom) for the required articulation was pretty intense, I came up with a few designs that required only 5 DOFs (with the same, or better, flight performance, in theory) over the next few years, but wondered if they would work, so naturally I started to work on the project once again...
After some thought and five large alterations to my initial design, I have finally found a design I believe is sufficient, the rest of this thread will document my progress as I build, fly [hopefully], optimize and redesign the aircraft.
Design/Project criteria
1). The flight battery (and any flight related system) will be entirely self-contained in the aircraft.
2). Ultimately using only the four [sets of] wings for lifting thrust and control.
3). Possess the ability to sustain flight in any flight heading and move horizontally without the [needed] change of heading.
4). Use only 5 DOFs for all the required articulation.
Aircraft overview
As mentioned earlier, there are 5 DOFs that ultimately will be used for normal control [Throttle, Yaw, Pitch and Roll] as well as linear movement [moving Forward, Backwards, Left and Right without Pitch/Roll rotation.] and "omniaxis" movement [hovering and linear flight at any angle of attack].
The required DOFs are as follows:
1. Rotation of left/forward wing, servo.
2. Rotation of right/forward wing, servo.
3. Rotation of right/rearward wing, servo.
4. Rotation or left/rearward wing, servo.
5. Wing power/frequency, motor.
And, YES, mixing will be "fun"...
Any questions/comments are appreciate!
Aircraft overview
