So there I was, flying my new DJI FPV quad ( which I love BTW ) and i Jerked my head around and the power cord fell off of the goggles. Luckily I was flying low to the ground above grass so I killed the motors and nothing was hurt. So I started searching the web to see what others did in my situation and I saw a few 3D printed gadgets that screwed into the side, but since I do not have a 3D printer i decided to use a 1/16th inch plastic cable clamp and it works like a charm. Here is a picture of what I used and how I hooked them up. I bought the cable clamps at Ace Hardware for 20 cents each.
DJI FPV goggles power cord falling out problem |
28-Jul-2020, 11:31 PM That's a good tip. I've read quite a few complaints about that issue. Other than custom 3D printed brackets that are readily available on Thingiverse, I've seen other people use the poor man's solution of a cable-tie to strap the power cord to the metal D-ring. Your solution is a nice halfway house between the two. |
Tutorial Lipo charger power supply made from old Xbox power brick | relentlesstech | 0 | 102 | 11-May-2024, 04:47 AM Last Post: relentlesstech | |
How To Corner FPV Like a Pro - Cornering Drones | mattyfleischfpv | 0 | 309 | 31-Jan-2024, 07:36 PM Last Post: mattyfleischfpv | |
Better FPV throttle control - Improve your stick movement FAST | mattyfleischfpv | 1 | 310 | 31-Jan-2024, 02:15 AM Last Post: Pathfinder075 | |
Problem with setting up bidirectional Dshot | Mlado53 | 4 | 3,605 | 09-Mar-2022, 04:46 PM Last Post: Mlado53 | |
FPV Angle Mix Mode. | AngryPepper | 2 | 5,193 | 02-Nov-2021, 07:18 PM Last Post: AngryPepper |
