26-Mar-2021, 03:30 AM
I have a DJI FPV Drone and V2 goggles...
I've activated the goggles with the DJI FPV drone and that all works perfectly.
I love it.
I also wanted to build a CineWhoop so I bought a DJI air unit.
I've activated the DJI air unit, but it won't bind to the V2 goggles.
The DJI assitant 2 correctly identified the Air unit
activated and updated the firmware.
Alas when I try to bind with the V2 goggles it wont bind.
Power up goggles and air unit.
Hit bind button on goggles and it starts beeping.
LED on air unit is green, I then push air unit bind button and it turns solid red.
Goggles continue to keep beeping...
Air unit never turns green goggles never stop beeping.
Goggles SW V 1.01 air unit software 1.060
The air unit also gets so hot you can't touch it.
(running on 4S battery)
Also bought DJI V1 FPV remote to go with Air unit.
These seem to bind successfully with the air unit.
The air unit was never turned on without antennas.
Other than tpower red lead and ground black lead none of the DJI airunit wires are attached to anything.
This is all on the bench...not in a quad.
Should it be so hot?
I love it.
