17-Jan-2021, 06:14 PM
How many channels should be available after implementing the 1200mw hack? My goggles have 700mw, 1000mw and 1200mw choices but I only have 4 channels. Is that correct or should I have 8?
DJI 1200 MW Hack and Number of Channels |
17-Jan-2021, 06:14 PM How many channels should be available after implementing the 1200mw hack? My goggles have 700mw, 1000mw and 1200mw choices but I only have 4 channels. Is that correct or should I have 8? 17-Jan-2021, 06:37 PM Do you have it set to 50Mbps? In 50Mbps mode you can only use channels 1, 2, and 3. In 25Mbps mode you'll have access to all 8 channels. https://oscarliang.com/50mbps-bitrate-dji-fpv/ 17-Jan-2021, 06:54 PM Any time you are experiencing missing channels or not the full 50Mbps after applying a firmware update or one of the hacks, do a factory reset of the goggles. 18-Jan-2021, 02:03 AM I think you nailed it V-22. I am 50Mpbs. I have channels 1, 2, 3, and 8. Currently flying on 2. 18-Jan-2021, 10:47 AM (18-Jan-2021, 02:03 AM)Skavage Wrote: I think you nailed it V-22. I am 50Mpbs. I have channels 1, 2, 3, and 8. Currently flying on 2. I like to use channel 3 for 50Mbps, as it has less chance of interfering with 5.8GHz WiFi. Note that even though channel 8 shows up in 50Mbps mode, it will only broadcast at 25Mbps. 23-Jan-2021, 04:38 PM Dang, nice chart V-22. Sounds like channel 3 is the place to be! |
Help New DJI O3 air unit will not connect to dji assistant 2 | Mattyylite | 2 | 174 | 16-Jun-2024, 01:59 AM Last Post: Mattyylite | |
Help DJI Air Unit, Goggles v2, and flysky rx/tx | mj451971 | 1 | 238 | 27-May-2024, 08:36 PM Last Post: mstc | |
Dji Goggles v2 or Integra? | jimskeet2002 | 11 | 4,910 | 24-May-2024, 04:19 PM Last Post: mattyfleischfpv | |
DJI Channel/Video Signal Strength in OSD | BadRaven | 2 | 246 | 08-May-2024, 09:28 PM Last Post: SnowLeopardFPV | |
DJI broadcast question | husafreak | 3 | 216 | 02-May-2024, 04:12 PM Last Post: husafreak |
