Threads: 20
Likes Received: 15 in 6 posts
Likes Given: 1
0 13-Aug-2018, 06:33 PM (This post was last modified: 13-Aug-2018, 06:34 PM by beastmode92.) I am looking for a GPS module for my quadcopter, but there are so many options I don't know which one to get.
There are the BN180, BN200, BN220, BN280 and BN880...
What are the differences between them?
Threads: 672
Likes Given: 2,030
139 So far from what I've gathered,
BN280 and BN-880 both have a compass (magnetometer) built in. These are pretty bulky for a mini quad.
There are smaller GPS modules, such as the BN180 and 220. These don't have Compass in them however. The BN-180 doesn't have flash memory for saving configuration while the BN-220 does.
Threads: 5
Likes Received: 7 in 4 posts
0 Specification of BN180 and BN200 is the same. What is the difference between BN200 and the others?
Threads: 0
Likes Received: 0 in 0 posts
0 I've looked into this a little myself, they use the same chipset and as far as i can tell they are all p[retty much the same with the exception of the last two which have a compass, the major difference being the size of the built in antenna. If you are using Betaflight the compass would be a waste of time. I opted for the BN-220 and as long as you can keep the smaller units away from your VTX & antenna you should be ok, which is easier said than done on a mini quad. Mounting is key to getting these cheaper units to work, if you want a hastle free install best buy a matek, they are more expensive but produce better results.
