Threads: 32
Likes Received: 0 in 0 posts
Likes Given: 1
0 Hello all. I just got my TBS Micro TX starter kit and connected it to my FC. It wasn't working correctly before so decided to factory reset both the TX and the Nano RX. Now, I plug in my battery and I get a solid red light. This is only when the transmitter is off. When I turn the transmitter on, it blinks twice quickly green, pauses, then blinks quickly green again. I see on my transmitter that I am connected to the RX, but I don't get any stick outputs in the receiver tab in Betaflight. I also can connect to the RX via LUA scripts. Lastly, when I try and bind in the LUA scripts, the light goes back to solid red on the RX. Does anyone know how to fix this?
Threads: 32
Likes Given: 1
0 Thanks for helping me fix that issue, the problem is, I have run into another issue. When I go to the receiver tab in Betaflight and move the sticks, (after the transmitter is connected to the drone), I see the values move, but all the values reset to defaults if I move any stick (throttle/yaw/pitch/roll) to the maximum position. The values are temporarily locked at the defaults until I move the stick from less than the maximum in either direction. I will post a video of the issue shortly.
Threads: 32
Likes Given: 1
0 UPDATE: I have fixed this issue by remapping the outputs on my transmitter. Thanks for the help @SnowLeopardFPV!
Threads: 76
Likes Received: 226 in 130 posts
Likes Given: 154
6 this processed saved me today as I was about to pull my hair out as to why a nano receiver I got used wouldn't bind... this turned out to be it. Thank you!
