27-Aug-2022, 05:05 PM
Hey guys, I'm new... please be gentle
I am using a switchable tx/rx setup. I have mounted both a tracer nano rx and crossfire nano rx in my dolphin and have one set of wires to plug into whichever one i want to use based on the flight ahead. Then i just swap out my radio module for whichever rx i have plugged in. I was able to get them both set up and installed all the firmware updates (tracer tx/rx on v6.19 and crossfire tx/rx on v6.19). I am running into a huge problem and haven't been able to find anything to help besides snowleopardfpv digging through others "dump" and fixing it from there in forums.
My tracer receiver and transmitter/radio are bound together and show solid green light. When i plugged into crossfire, i was able to pop in my crossfire module and bind them up and update them just fine as well. However, whenever i try to use the stick inputs in iNav receiver tab, i get nothing at all, completely unresponsive. I am however, able to test my motor through iNav slider ONLY. I also get "telemetry lost, telemetry recovered" when im plugging and unplugging so i know its working... just not as i want it to.. Also tested with Lipo, same results. I am running iNav 5.1
I have wired it up correctly and checked several times to be sure. Rx to Tx, Tx to RX.. I have it plugged into UART2 on MatekH743-WingV3. In iNav, I have port 2 set as serial Rx. I have GPS on UART6 and it gets 12 satellites while inside so that's working. I have receiver set to Serial, CRSF, inverter off, half duplex or whatever set to auto, but i have tried switching these settings around to no avail. My model has its internal RF off and external set to CRSF, however I am new and really haven't done anything else in model settings, not sure if there's more for me to do besides that. Anyways, I was hoping to see if anyone can please help, i just wanna fly I am willing to add pictures and whatever else you guys need from me.
