09-Jun-2018, 03:06 AM
can I connect the fpv transmitter directly to bat power. or do I need a port on the fc with over 7 volts. is 7-24 volts ?
thanks Fisher King.
thanks Fisher King.
connecting fpv trans. |
09-Jun-2018, 03:06 AM can I connect the fpv transmitter directly to bat power. or do I need a port on the fc with over 7 volts. is 7-24 volts ? thanks Fisher King. 09-Jun-2018, 03:08 AM I may of toasted the port that it's on when my fpv ant. shorted with my bat F.K. 09-Jun-2018, 04:03 AM As long as it is 5s or less for 7-24V. 09-Jun-2018, 12:49 PM (This post was last modified: 09-Jun-2018, 12:49 PM by Fisherking.) 09-Jun-2018, 12:55 PM What VTX are you referring to? 09-Jun-2018, 01:20 PM 09-Jun-2018, 01:45 PM (09-Jun-2018, 01:20 PM)Fisherking Wrote: the one for the Eachine 220x. a replace ment . I thought I blew the old one in a crash and my bat shorted it. the VTX that comes with the Eachine 220X is rated for 7V to 24V according to the spec, so you should be able to power it directly from LiPo. 09-Jun-2018, 02:15 PM 10-Jun-2018, 02:24 AM (This post was last modified: 10-Jun-2018, 02:27 AM by Fisherking.) 10-Jun-2018, 04:33 AM Neg of capacitor to neg lipo pad Pos of capacitor to pos lipo pad 10-Jun-2018, 02:10 PM so would I use a 25v if I'm going to use 5s in the future or am I looking at the voltage to the Vtx? as the rate of the cap? Thanks F.K. 10-Jun-2018, 02:53 PM (10-Jun-2018, 02:10 PM)Fisherking Wrote: so would I use a 25v if I'm going to use 5s in the future or am I looking at the voltage to the Vtx? as the rate of the cap? 25v would be at the limit of the vtx voltage capacicty (how much power it will allow before it fries). Wiring +\- to Lipo connection on the FC would keep you within the tolerable range as long as you use up to 5s. The capacitor mentioned above will filter voltage spikes protecting components and allowing for a cleaner video feed. 1000 uf should be sufficient for your stated use. 10-Jun-2018, 05:48 PM 25V is good. 10-Jun-2018, 08:55 PM (10-Jun-2018, 02:53 PM)MarkII Wrote: 25v would be at the limit of the vtx voltage capacicty (how much power it will allow before it fries). Wiring +\- to Lipo connection on the FC would keep you within the tolerable range as long as you use up to 5s. The capacitor mentioned above will filter voltage spikes protecting components and allowing for a cleaner video feed. 1000 uf should be sufficient for your stated use.so just those capacitors with the two ends soldered on to the pads of the bat +&- that's it the solder the Vtx onto the pads as well ? Thanks Fisher King. 10-Jun-2018, 08:58 PM |
FPV freestyle drone | NewToFPV | 23 | 917 | Yesterday, 02:44 PM Last Post: NewToFPV | |
Trouble connecting taranis X-lite pro to Win 11 USB | skipSSnova | 7 | 2,310 | 05-May-2024, 05:46 PM Last Post: BadRaven | |
Flylens 85 not connecting | soky157 | 51 | 673 | 04-May-2024, 01:16 AM Last Post: SeismicCWave | |
Help for building an fpv drone | NewToFPV | 1 | 119 | 26-Apr-2024, 12:44 PM Last Post: SnowLeopardFPV | |
problems connecting and writing code for the remote (esp32) and the flight controller | YarikVor | 2 | 133 | 23-Apr-2024, 03:58 PM Last Post: YarikVor |
