24-Jul-2022, 12:00 AM
Review: https://oscarliang.com/speedybee-flex25/
defaults nosave
###WARNING: NO CUSTOM DEFAULTS FOUND###
# Betaflight / STM32F745 (S745) 4.2.8 Feb 15 2021 / 12:10:00 (101738d8e) MSP API: 1.43
###ERROR: diff: NO CONFIG FOUND###
# start the command batch
batch start
defaults nosave
board_name FLYWOOF745HEX
manufacturer_id FLWO
mcu_id 004300383538510f39303632
signature
# name: FLYWOO
# resources
resource BEEPER 1 D15
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 E09
resource MOTOR 4 E11
resource MOTOR 5 C09
resource MOTOR 6 A03
resource MOTOR 7 B04
resource MOTOR 8 B05
resource PPM 1 E13
resource LED_STRIP 1 D12
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 D05
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 A00
resource SERIAL_TX 5 C12
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 E08
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 D06
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 D02
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 E07
resource I2C_SCL 1 B06
resource I2C_SDA 1 B07
resource LED 1 A02
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 4 E02
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 4 E05
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 4 E06
resource ADC_BATT 1 C03
resource ADC_RSSI 1 C05
resource ADC_CURR 1 C02
resource PINIO 1 C00
resource FLASH_CS 1 A04
resource OSD_CS 1 B12
resource GYRO_EXTI 1 E01
resource GYRO_CS 1 E04
resource USB_DETECT 1 A08
# timer
timer E13 AF1
# pin E13: TIM1 CH3 (AF1)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer E09 AF1
# pin E09: TIM1 CH1 (AF1)
timer E11 AF1
# pin E11: TIM1 CH2 (AF1)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer A03 AF2
# pin A03: TIM5 CH4 (AF2)
timer B03 AF1
# pin B03: TIM2 CH2 (AF1)
timer B04 AF2
# pin B04: TIM3 CH1 (AF2)
timer B05 AF2
# pin B05: TIM3 CH2 (AF2)
timer D12 AF2
# pin D12: TIM4 CH1 (AF2)
# dma
dma ADC 1 1
dma pin E13 1
# pin E13: DMA2 Stream 6 Channel 6
dma pin B00 0
dma pin B01 0
dma pin E09 2
# pin E09: DMA2 Stream 3 Channel 6
dma pin E11 1
# pin E11: DMA2 Stream 2 Channel 6
dma pin C09 0
dma pin A03 0
# pin A03: DMA1 Stream 1 Channel 6
dma pin B03 0
dma pin B04 0
dma pin B05 0
dma pin D12 0
# pin D12: DMA1 Stream 0 Channel 2
# mixer
mixer HEX6X
mmix 0 1.000 -0.500 0.866 1.000
mmix 1 1.000 -0.500 -0.866 1.000
mmix 2 1.000 0.500 0.866 -1.000
mmix 3 1.000 0.500 -0.866 -1.000
mmix 4 1.000 -1.000 0.000 -1.000
mmix 5 1.000 1.000 0.000 1.000
feature RX_SERIAL
feature MOTOR_STOP
feature TELEMETRY
feature LED_STRIP
feature OSD
serial 1 0 115200 9600 0 115200
serial 2 1 115200 57600 0 115200
led 0 6,7::CO:8
led 1 7,7::CO:8
led 2 8,7::CO:8
led 3 9,7::CO:8
aux 0 0 1 1300 2100 0 0
aux 1 2 1 1700 2100 0 0
# rxfail
rxfail 6 s 2000
# master
set gyro_lowpass2_hz = 325
set dyn_lpf_gyro_min_hz = 260
set dyn_lpf_gyro_max_hz = 650
set acc_calibration = -2,32,-41,1
set mag_bustype = I2C
set mag_i2c_device = 1
set mag_hardware = NONE
set baro_bustype = I2C
set baro_i2c_device = 1
set rssi_channel = 15
set serialrx_provider = CRSF
set current_meter = NONE
set battery_meter = ADC
set ibata_scale = 175
set beeper_inversion = ON
set beeper_od = OFF
set yaw_motors_reversed = ON
set small_angle = 180
set gps_rescue_min_sats = 5
set pid_process_denom = 2
set osd_vbat_pos = 2304
set osd_rssi_pos = 2208
set osd_rssi_dbm_pos = 128
set osd_tim_1_pos = 2400
set osd_tim_2_pos = 2368
set osd_flymode_pos = 2272
set osd_vtx_channel_pos = 2325
set osd_craft_name_pos = 2080
set osd_gps_speed_pos = 185
set osd_gps_lon_pos = 49
set osd_gps_lat_pos = 17
set osd_gps_sats_pos = 250
set osd_home_dir_pos = 217
set osd_home_dist_pos = 217
set osd_flight_dist_pos = 2201
set osd_altitude_pos = 2135
set osd_warnings_pos = 2441
set osd_avg_cell_voltage_pos = 2336
set osd_disarmed_pos = 2411
set osd_flip_arrow_pos = 2112
set osd_core_temp_pos = 2169
set osd_log_status_pos = 2144
set max7456_spi_bus = 2
set dashboard_i2c_bus = 1
set flash_spi_bus = 1
set gyro_1_bustype = SPI
set gyro_1_spibus = 4
set gyro_1_align_yaw = 2700
set gyro_2_spibus = 4
set name = FLYWOO
# profile 0
set dyn_lpf_dterm_min_hz = 91
set dyn_lpf_dterm_max_hz = 221
set dterm_lowpass2_hz = 195
set anti_gravity_gain = 5000
set iterm_relax_cutoff = 20
set p_pitch = 45
set i_pitch = 63
set d_pitch = 52
set f_pitch = 74
set p_roll = 41
set i_roll = 59
set d_roll = 48
set f_roll = 69
set p_yaw = 44
set i_yaw = 63
set f_yaw = 69
set d_min_roll = 31
set d_min_pitch = 34
set d_min_boost_gain = 27
profile 1
profile 2
# rateprofile 0
set tpa_breakpoint = 1250
rateprofile 1
rateprofile 2
rateprofile 3
rateprofile 4
rateprofile 5
rateprofile 2
# save configuration
