Here's my last working CLI dump for the Flywoo Baby Quad (not stock CLI).
Board: FLWO/FLYWOOF745NANO(STM32F745), loaded with Betaflight version 4.2.0
Review: https://oscarliang.com/flywoo-baby-quad/
# resources
resource BEEPER 1 D15
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 E09
resource MOTOR 4 E11
resource MOTOR 5 C09
resource MOTOR 6 A03
resource MOTOR 7 B04
resource MOTOR 8 B05
resource PPM 1 E13
resource LED_STRIP 1 D12
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 D05
resource SERIAL_TX 3 D08
resource SERIAL_TX 4 A00
resource SERIAL_TX 5 C12
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 E08
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 D06
resource SERIAL_RX 3 D09
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 D02
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 E07
resource I2C_SCL 1 B06
resource I2C_SCL 2 B10
resource I2C_SDA 1 B07
resource I2C_SDA 2 B11
resource LED 1 A02
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 4 E02
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 4 E05
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 4 E06
resource ADC_BATT 1 C03
resource ADC_RSSI 1 C05
resource ADC_CURR 1 C02
resource PINIO 1 C00
resource FLASH_CS 1 A04
resource OSD_CS 1 B12
resource GYRO_EXTI 1 E01
resource GYRO_CS 1 E04
resource USB_DETECT 1 A08
# timer
timer E13 AF1
# pin E13: TIM1 CH3 (AF1)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer E09 AF1
# pin E09: TIM1 CH1 (AF1)
timer E11 AF1
# pin E11: TIM1 CH2 (AF1)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer A03 AF2
# pin A03: TIM5 CH4 (AF2)
timer B03 AF1
# pin B03: TIM2 CH2 (AF1)
timer B04 AF2
# pin B04: TIM3 CH1 (AF2)
timer B05 AF2
# pin B05: TIM3 CH2 (AF2)
timer D12 AF2
# pin D12: TIM4 CH1 (AF2)
# dma
dma ADC 1 1
dma pin E13 1
# pin E13: DMA2 Stream 6 Channel 6
dma pin B00 0
dma pin B01 0
dma pin E09 2
# pin E09: DMA2 Stream 3 Channel 6
dma pin E11 1
# pin E11: DMA2 Stream 2 Channel 6
dma pin C09 0
dma pin A03 0
# pin A03: DMA1 Stream 1 Channel 6
dma pin B03 0
dma pin B04 0
dma pin B05 0
dma pin D12 0
# pin D12: DMA1 Stream 0 Channel 2
# mixer
mmix 0 1.000 -0.809 0.659 -1.000
mmix 1 1.000 -1.000 -0.659 1.000
mmix 2 1.000 0.809 0.659 1.000
mmix 3 1.000 1.000 -0.659 -1.000
feature RX_SERIAL
feature TELEMETRY
feature LED_STRIP
feature OSD
# beacon
beacon RX_SET
serial 1 0 115200 9600 0 115200
serial 2 1 115200 57600 0 115200
serial 4 1 115200 57600 0 115200
led 0 6,6::CO:8
led 1 7,6::CO:8
led 2 8,6::CO:8
led 3 9,6::CO:8
aux 0 0 0 1700 2100 0 0
aux 1 1 1 1700 2100 0 0
aux 2 13 2 1700 2100 0 0
aux 3 35 2 1700 2100 0 0
# rxfail
rxfail 6 s 2000
# master
set gyro_lowpass2_hz = 325
set dyn_lpf_gyro_min_hz = 260
set dyn_lpf_gyro_max_hz = 650
set acc_calibration = 71,-69,-15,1
set mag_bustype = I2C
set mag_i2c_device = 1
set mag_hardware = NONE
set baro_bustype = I2C
set baro_i2c_device = 1
set baro_hardware = NONE
set min_check = 1010
set serialrx_provider = CRSF
set blackbox_p_ratio = 64
set current_meter = ADC
set battery_meter = ADC
set ibata_scale = 200
set beeper_inversion = ON
set beeper_od = OFF
set beeper_dshot_beacon_tone = 3
set small_angle = 180
set gps_sbas_mode = AUTO
set gps_rescue_min_sats = 5
set deadband = 4
set yaw_deadband = 4
set osd_vbat_pos = 2436
set osd_rssi_pos = 2177
set osd_rssi_dbm_pos = 161
set osd_tim_1_pos = 353
set osd_tim_2_pos = 2485
set osd_flymode_pos = 193
set osd_throttle_pos = 2445
set osd_vtx_channel_pos = 161
set osd_current_pos = 2476
set osd_mah_drawn_pos = 2404
set osd_craft_name_pos = 2089
set osd_gps_speed_pos = 216
set osd_gps_lon_pos = 81
set osd_gps_lat_pos = 49
set osd_gps_sats_pos = 119
set osd_home_dir_pos = 142
set osd_home_dist_pos = 152
set osd_flight_dist_pos = 184
set osd_compass_bar_pos = 10
set osd_altitude_pos = 279
set osd_warnings_pos = 14634
set osd_avg_cell_voltage_pos = 2468
set osd_disarmed_pos = 2315
set osd_flip_arrow_pos = 65
set osd_core_temp_pos = 248
set osd_log_status_pos = 97
set osd_efficiency_pos = 231
set debug_mode = GYRO_SCALED
set scheduler_optimize_rate = ON
set max7456_spi_bus = 2
set dashboard_i2c_bus = 1
set flash_spi_bus = 1
set gyro_1_bustype = SPI
set gyro_1_spibus = 4
set gyro_1_align_yaw = 2700
set gyro_2_spibus = 4
set name = FLYWOOF7NANO
# profile 0
set dyn_lpf_dterm_min_hz = 91
set dyn_lpf_dterm_max_hz = 221
set dterm_lowpass2_hz = 195
set anti_gravity_gain = 5000
set iterm_relax_cutoff = 20
set p_pitch = 52
set i_pitch = 63
set d_pitch = 68
set f_pitch = 80
set p_roll = 47
set i_roll = 59
set d_roll = 63
set f_roll = 76
set p_yaw = 50
set i_yaw = 63
set f_yaw = 76
set d_min_roll = 41
set d_min_pitch = 45
set d_min_boost_gain = 27
# rateprofile 0
set roll_rc_rate = 110
set pitch_rc_rate = 110
set yaw_rc_rate = 110
set roll_expo = 7
set pitch_expo = 10
set yaw_expo = 10
set roll_srate = 72
set pitch_srate = 72
set yaw_srate = 72
set tpa_breakpoint = 1250
# end the command batch
batch end
