CLI / displayport_msp_serial is invalid
I try to setup OSD for a Walksnail Avatar Mini 1S on a iFlight SucceX-E F405 Mini. When i try to set displayport_msp_serial it fails. Does anyone know what's the probleme here?
# Betaflight / STM32F405 (S405) 4.4.0 Feb  1 2023 / 23:28:11 (4605309d8) MSP API: 1.45
# config: YES
# board: manufacturer_id: FPVM, board_name: BETAFLIGHTF4
# set displayport_msp_serial = 2
###ERROR IN set: INVALID NAME: displayport_msp_serial = 2###
You don't do that anymore under Betaflight 4.4. Instead you need to go to the Ports tab in Betaflight Configurator and for the UART that is being used for MSP (in your case UART3) you need to select "VTX (MSP + Displayport)" from the dropdown in the Peripherals column and then click the "Save and Reboot" button at the bottom.
  • Bumpster
Yep, that works, thanks
(17-Mar-2023, 12:32 PM)SnowLeopardFPV Wrote: You don't do that anymore under Betaflight 4.4. Instead you need to go to the Ports tab in Betaflight Configurator and for the UART that is being used for MSP (in your case UART3) you need to select "VTX (MSP + Displayport)" from the dropdown in the Peripherals column and then click the "Save and Reboot" button at the bottom.
Thanks..that's really helpful..Fixed my problem too!  Smile
  Mamba 411 16x16 Full UART for CRSF CLI jasc 35 9,477 23-Sep-2023, 10:41 PM
Last Post: GSixx8
  Help Did I brick my FC via CLI? dehein2 20 697 05-Sep-2023, 05:29 AM
Last Post: dehein2
  Help Diatone MAMBA F405 MINI DJI FC default CLI dump or soft serial setup Original 12 2,586 27-May-2023, 12:38 PM
Last Post: Original
  set spi for flysky in the cli hugnosed_bat 3 446 26-Jan-2023, 11:02 AM
  Help Stock cli dump for JHEMCU ghf420aio 35a Lemonyleprosy 0 476 28-Aug-2021, 10:03 PM
Last Post: Lemonyleprosy
