Threads: 81
Likes Received: 14 in 9 posts
Likes Given: 17
1 Does anyone have this combo? I bought mine and when I got it the receiver has heat shrink over the bind button. Am I supposed to cut the heat shrink or is there a different way to bind. I also have a BetaFPV 65 Pro whoop that I can bind in the CLI but I tried that mode and it did not work.
Thanks
Don
Threads: 586
Likes Received: 8,958 in 6,629 posts
Likes Given: 1,425
786 You can only bind the SPI receivers (which your Beta65 Pro has) and Spektrum receivers using CLI commands.
With the R-XSR you have to press the bind button on it. Sometimes you can press the button through the heatshrink, but if not then you might get away with poking a hole in the heatshrink with a pin so you can then use a something through the hole to press the button which will avoid having to cut the heatshrink off and then apply a new piece again afterwards.
Threads: 81
Likes Given: 17
1 The manufactures know that the receivers have to be bound, why don't they make it easier to bind??? Thanks for all your help. I also looked at GepRC's site and they do not even have a manual for this model.
Threads: 125
Likes Given: 99
388 Pressing the button with shrink wrap is easy. Usually not a problem. I rather have it that way instead of receiver coming unwrap and you having to desolder everything to shrink wrap yourself.
