18-Feb-2023, 02:04 AM
To anyone who has/had the GEPRC CineBot30 O3, are there any tips or tricks that might make it easier to access the microSD card and/or the binding/linking button?
Thanks!
Thanks!
CineBot30 O3 |
18-Feb-2023, 02:04 AM To anyone who has/had the GEPRC CineBot30 O3, are there any tips or tricks that might make it easier to access the microSD card and/or the binding/linking button? Thanks! 19-Feb-2023, 11:22 PM Ceramic tweezers may help. (18-Feb-2023, 02:04 AM)GClef Wrote: To anyone who has/had the GEPRC CineBot30 O3, are there any tips or tricks that might make it easier to access the microSD card and/or the binding/linking button?Edit: When I first posted this, I did not understand the question. The first 2 tips below relate to the micro USB connector used to connect to betaflight. If by micro SD card, you mean the the micro usb connector (the one you connect for BetaFlight), there are two things I've tried. 1. using a micro usb connector with a thin width on the insulation part. 2. Holding the side of the connector right up against the frame part to the right (looking into the connector), and starting at a slight angle to the to the right. Now that I've done it a bunch, I find #2 good enough. I'm not aware of a removable micro SD card--if there is one, I'd like to replace it with a larger capacity, since the bot can only record 20G, which is good for about two battery packs. Lately I've been connecting to my phone after two batteries to move the files onto phone--takes about 10 minutes. (Edit: I added a 64G micro SD card when I rebuilt the quad). I had to take the top off to get to the binding button, but that isn't the way I eventually got it bound. I used the connect/disconnect 2 times then connect method (so connect, disconnect, connect, disconnect, connect), and that worked great. (Edit: this is for binding the receiver to the transmitter.) As an additional tip, a right angle USB connector is easier to use for the O3 USB C connector. Edit: this is very useful, and is what I still do. (18-Feb-2023, 02:04 AM)GClef Wrote: To anyone who has/had the GEPRC CineBot30 O3, are there any tips or tricks that might make it easier to access the microSD card and/or the binding/linking button? After disassembling my Cinebot after a recent crash where I tossed a motor (posted about it elsewhere here), I see what you're talking about. I didn't even know there was a micro SD card slot. It's shown in the O3 manual, but I never had looked at that before. I actually saw it in the manual first, and was like "huh?", then found it on the O3 unit. Even with frame apart and motors off. It looks like you'd have to use tweezers to get at the card. The antenna wire also may be obscuring the card slot. There are only 4 screws holding the O3 unit to the frame, so easy enough to just remove it.
