Threads: 81
Likes Received: 14 in 9 posts
Likes Given: 17
1 Never bought or made anything from carbon fiber but I do have a question. I have built a GepRC Mark 4 HDV about a year ago'ish, I have crashed it multiple times, some of them hard crashes, and apart from the minor scratches and dirt, it looks like a new frame. I recently built a frame from what I thought was a good name brand (won't mention name here) and on my third flight came a little too close to the grass in the park and planted it in the mud, which I did not think was too hard of a crash. After cleaning it up I noticed that the end of the carbon as it sticks out from the motor was broken off and the carbon is splintering. Maybe I hit harder than I thought but I am wondering if some frame makers are using lower quality carbon. Is that a known thing???
Don
Threads: 49
Likes Received: 192 in 157 posts
Likes Given: 186
11 29-May-2021, 06:42 PM (This post was last modified: 29-May-2021, 06:44 PM by Kevin2112.) Feel free to mention the name! Inquiring minds like to know. I like to put TPU printed bumpers covering the ends of the arms. Yeah they add a little weight but not enough to effect flight on a bigger quad.
Threads: 125
Likes Given: 99
388 There are different quality of carbon fiber. And I have to agree with you, whatever CF GEPRC uses, it is tough.
Threads: 172
Likes Received: 2,299 in 1,845 posts
Likes Given: 4,755
103 there is the thikness of the fibers (? i believe so); 12k carbon, 3k carbon.
there is also a label "t700" carbon, "t800". i dont understand that rating.
one of the best carbon fiber quality i own on a frame is the carbon on the flightclub tokio/proton.
the best might be my hand moulded carbon frame, from the manufacturer of the stardust frames. actual hand moulded can be the best, the fiber directions can be freely added to get the best out of a frame geometry.
informations about your settup.. battery weight.. buildweight... we can probably suggest a matching frame.
Threads: 57
Likes Received: 254 in 227 posts
Likes Given: 102
12 there are definitely different quality carbon fibers... however, you could have had the same quality on both quads and experienced the exact same thing. What you might think as a soft crash might be worse than what you'd think a hard crash is based on the angle and many other factors.
I've crashed smack into the concrete with no damage at all, and on the same frame crashed in dirt and lost two arms...... Anyway my point is that this is not a sufficient test to decide whether or not one carbon is better than the other.........
In this case I think it just comes down to knowledge and experience seeing quality carbon. Either that or just straight up KNOWING.
'Ignore' is the route word of Ignorant.
Threads: 172
Likes Given: 4,755
103 i have lifetime warranty on my flightclub tokio too
