Threads: 3
Likes Received: 0 in 0 posts
Likes Given: 2
0 Guys, I think I am getting some noise - a little bit of horizontal scanning lines appear when I throttle up, they can be somehow seen on the beginning of this video:
Can you check it out and tell me if that's fine, and I won't get any better than that in terms of video quality?
Or maybe adding low esr cap to battery leads would help? ( I did not add any on this quad)
Threads: 67
Likes Received: 713 in 473 posts
Likes Given: 1,216
23 I cap would probably help, but I wouldn't bother, particularly since it's your flight video. It appears to be very slight. Just my .02 cents worth.
Threads: 50
Likes Received: 832 in 504 posts
Likes Given: 372
51 Honestly, that's better video than either of my quads!
However a capacitor is never a bad idea. I have one on one of my quads since the noise back off the ESCs was causing the camera to cut out completely on flips. If you're curious about this stuff then Drone Mesh did a few videos comparing LC filters and different capacitors.
Threads: 29
Likes Received: 279 in 168 posts
Likes Given: 242
6 Your video doesn't look bad at all. You could add a cap but I've seen much worse. I've used both LC filters and caps. On one of mine the LC filter worked perfectly, on another the filter did nothing and I had to use a cap. Depends on the frequency and cause of the noise.
Threads: 26
Likes Received: 37 in 25 posts
Likes Given: 68
2 Your fpv video is really better than mine too.
I added a 1000uf low esr 25v on lipo pads on fc. It helped a lot with twitchings problem but just a little or almost nothing on video quality
Threads: 125
Likes Given: 99
388 I think most of us would be happy with video like this without cap.
Threads: 63
Likes Received: 93 in 70 posts
Likes Given: 26
1 I want to use the LC, but my Armattan Rooster have zero space to stick it in.
