Posts: 536 Threads: 19 Likes Received: 261 in 173 posts Likes Given: 168 Joined: Sep 2018 Reputation: 10 I can connect my FC to betaflight as normal and everything works as it should, but when i press the boot button and connect USB to flash firmware it fails to open serial port and can't connect to my FC. I have tried the guide below but the problems he solves doesn't seem to be the same. • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 09-Jan-2019, 06:54 PM (This post was last modified: 09-Jan-2019, 06:55 PM by voodoo614.) Are you seeing DFU in the upper right of BFC when you boot into bootloader mode? You have to at least see that. If you are not seeing it, then there is something wrong with your driver or FC. Can you also show me what settings you have clicked when you flash? Eg. No boot sequence, full chip erase etc. Also what FC do you have. • Posts: 536 Threads: 19 Likes Received: 261 in 173 posts Likes Given: 168 Joined: Sep 2018 Reputation: 10 Not sure what DFU is? if i connect USB it detects the COM7, but if i hold boot and connect USB nothing happens in BFC. not I have a F4 magnum board, OMNIBUSF4 firmware. • Posts: 21,130 Threads: 580 Likes Received: 8,906 in 6,586 posts Likes Given: 1,424 Joined: Jun 2018 Reputation: 784 09-Jan-2019, 08:47 PM (This post was last modified: 09-Jan-2019, 08:48 PM by SnowLeopardFPV.) Have you tried running the ImpulseRC driver fixer? If not then try doing that next. It can be downloaded from the following web page... https://impulserc.com/pages/downloads • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 You will need to install the Zadig driver to flash for your FC. Follow the tutorial below. • Posts: 536 Threads: 19 Likes Received: 261 in 173 posts Likes Given: 168 Joined: Sep 2018 Reputation: 10 Thanks guys, this is really strange.. when i connect the USB - FC windows detects a USB device, zadig finds it and i can install the right driver just like in the video above. But when i press boot and plug in the USB nothing happens, windows doesn't detect anything and the device cant be found in zadig.. the only thing that works as it supposed to do is the blue LED on the FC in bootloader mode. • Posts: 21,130 Threads: 580 Likes Received: 8,906 in 6,586 posts Likes Given: 1,424 Joined: Jun 2018 Reputation: 784 When in DFU/boot mode, do any unrecognised devices with a yellow exclamation mark against them show up for it in Windows Device Manager? Also, I take it you've tried a different USB cable to eliminate any possible dodgyness with the cable itself? Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 09-Jan-2019, 10:38 PM (This post was last modified: 09-Jan-2019, 10:42 PM by voodoo614.) You can force DFU mode through BFC. Go to setup tab. Toggle expert mode top right. Restart BFC. Go to Setup tab again. You should see a button top miide for bootloader mode. Click that. Hopefully that will get you into DFU/bootloader mode. Posts: 536 Threads: 19 Likes Received: 261 in 173 posts Likes Given: 168 Joined: Sep 2018 Reputation: 10 (09-Jan-2019, 10:13 PM)SnowLeopardFPV Wrote: When in DFU/boot mode, do any unrecognised devices with a yellow exclamation mark against them show up for it in Windows Device Manager? Also, I take it you've tried a different USB cable to eliminate any possible dodgyness with the cable itself? Nothing shows up in device manager and zadig cant seem to find any devices in DFU mode. Tried different cables and they all work when not connecting in DFU mode. • Posts: 536 Threads: 19 Likes Received: 261 in 173 posts Likes Given: 168 Joined: Sep 2018 Reputation: 10 (09-Jan-2019, 10:38 PM)voodoo614 Wrote: You can force DFU mode through BFC. Go to setup tab. Toggle expert mode top right. Restart BFC. Go to Setup tab again. You should see a button top miide for bootloader mode. Click that. Hopefully that will get you into DFU/bootloader mode. I dont have this button in BFC even if i follow your instructions.. i have version 10.4.0 Tried to enter DFU in BFC by typing BL like in the instruction below. The blue LED lights up as it should and i hear windows disconnect the USB device and then BFC crashes.. • Posts: 536 Threads: 19 Likes Received: 261 in 173 posts Likes Given: 168 Joined: Sep 2018 Reputation: 10 Solved! Okay, while forcing the board in CLI to enter DFU mode windows somehow just detected the usb device and i could replace the driver with zadig and now i can access the FC in DFU mode latest firmware now successfully flashed and everything seems fine thanks for the help, i would not have figured this out on my own. forcing into DFU mode through BFC did the trick • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 (16-Jan-2019, 07:55 PM)Andreas-sa Wrote: I dont have this button in BFC even if i follow your instructions.. i have version 10.4.0 BFC 10.4.0 definitely has the DFU/Bootloader button. The screenshot I posted is from 10.4.0 BFC. Good you got it to work. I found for some reason the button works more consistently than "DFU" in CLI. • Posts: 536 Threads: 19 Likes Received: 261 in 173 posts Likes Given: 168 Joined: Sep 2018 Reputation: 10 (16-Jan-2019, 09:19 PM)voodoo614 Wrote: BFC 10.4.0 definitely has the DFU/Bootloader button. The screenshot I posted is from 10.4.0 BFC. Good you got it to work. I found for some reason the button works more consistently than "DFU" in CLI. That's strange, I did not have the button until I upgraded the firmware, now it's there. Maybe it depends on what BF version the FC have? • Posts: 21,130 Threads: 580 Likes Received: 8,906 in 6,586 posts Likes Given: 1,424 Joined: Jun 2018 Reputation: 784 17-Jan-2019, 10:26 AM (This post was last modified: 17-Jan-2019, 10:27 AM by SnowLeopardFPV.) (17-Jan-2019, 08:02 AM)Andreas-sa Wrote: That's strange, I did not have the button until I upgraded the firmware, now it's there. Maybe it depends on what BF version the FC have? Yes, that's correct. Having just looked at the Betaflight Configurator 10.4.0 source code, the "Activate Boot Loaded / DFU" button only gets displayed on the Setup tab if the "MSP API Version" of the Betaflight firmware on the Flight Controller is version 1.40.0 or greater. Looking at the the source code for the Betaflight firmware itself, the "MSP API Version" was incremented to 1.40.0 in Betaflight 3.5.0. So, you need Betaflight firmware version 3.5.0 or greater installed on your Flight Controller for that "Activate Boot Loaded / DFU" button to appear in Betaflight Configurator • Posts: 536 Threads: 19 Likes Received: 261 in 173 posts Likes Given: 168 Joined: Sep 2018 Reputation: 10 (17-Jan-2019, 10:26 AM)SnowLeopardFPV Wrote: Yes, that's correct. Having just looked at the Betaflight Configurator 10.4.0 source code, the "Activate Boot Loaded / DFU" button only gets displayed on the Setup tab if the "MSP API Version" of the Betaflight firmware on the Flight Controller is version 1.40.0 or greater. Looking at the the source code for the Betaflight firmware itself, the "MSP API Version" was incremented to 1.40.0 in Betaflight 3.5.0. So, you need Betaflight firmware version 3.5.0 or greater installed on your Flight Controller for that "Activate Boot Loaded / DFU" button to appear in Betaflight Configurator That explains it, and if you have Betaflight firmware prior to 3.5.0 you can type "BL" in CLI which does the same thing. • |
