30-Jan-2021, 04:40 AM
I was reading a post that said that tiny whoop motors especially 19,000 KV can go bad within two hours of flight time is this true?
can tiny whoop motors go bad quick? |
30-Jan-2021, 04:40 AM I was reading a post that said that tiny whoop motors especially 19,000 KV can go bad within two hours of flight time is this true? 30-Jan-2021, 04:47 AM The little 6mm brushed motors can loose their fire pretty fast. If you are keeping them throttled up all the time, they will start to slow as they wear out. I usually have to replace a set of the typical brushed. Motors after about. 4 to 6 hours. SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) 30-Jan-2021, 04:54 AM (30-Jan-2021, 04:47 AM)kaitylynn Wrote: The little 6mm brushed motors can loose their fire pretty fast. If you are keeping them throttled up all the time, they will start to slow as they wear out. what about brushless? sorry i should have been more specific. 30-Jan-2021, 05:18 AM Brushless motors are going to last as long as the bearings last. 19,000 rpm is pretty fast...likely they will fly fine for months (if you fly a lot) as long as they do not get damaged in crashes. SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) 30-Jan-2021, 09:41 AM brushless motors should last long without physical damage. do you get very very hot motors? to much heat can burn a motor your battery will more likely bad than your motors 01-Feb-2021, 10:56 AM Do not go anywhere near dusty.. or dirt. You cant see it. Motors are vacuuming it up. Eventually... brrrrrr Bring a pizza box launch pad. |
1102 motors on a 65mm pusher? | ph2t | 31 | 964 | 04-May-2024, 01:40 PM Last Post: ph2t | |
Ordered the HDZERO mob6 with the eco camera and 28k motors | Rob Axel | 35 | 1,289 | 21-Apr-2024, 06:25 PM Last Post: iFly4rotors | |
Build 1106 motors on 4S for a 2" prop | mstc | 10 | 301 | 19-Apr-2024, 06:30 PM Last Post: mstc | |
Build Flylens85 Walksnail 3S cruise whoop build | mstc | 8 | 356 | 04-Apr-2024, 05:14 AM Last Post: Cyberess | |
LHCP ufl Antenna suggestion for 80mm whoop | Maverick | 19 | 973 | 12-Mar-2024, 11:41 AM Last Post: Yohfpv |
