Can't do back flip w/ out quad making weird prop noise.
Hello Folks,
 Can't do back flips. The quad over shoots and makes that weird prop noise. I belief I'm not dialing in the correct settings. Or the ESC is a dud, but this is the 2nd ESC and it's doing the same thing as the first.
I looked at the BB log and see that the blue line on the graph does not make a nice square as my other quads do when I look at their graphs. What can I do to dial in the settings to make the quad do backflips.  Attached is the BB file. Hope someone can help before I have to send everything back to China. Thank you.
# diff all
# Betaflight / STM32F7X2 (S7X2) 4.2.9 Apr 27 2021 / 19:34:29 (e097f4ab7) MSP
API: 1.43
# config: manufacturer_id: DIAT, board_name: MAMBAF722_I2C, version:
ec268d11, date: 2021-07-26T13:10:45Z
# start the command batch
batch start
defaults nosave
board_name MAMBAF722_I2C
manufacturer_id DIAT
mcu_id 001d00394638501120383937
signature
# name: HD1 w/ Vanny arm
# resources
resource MOTOR 1 A09
resource MOTOR 2 A08
resource MOTOR 3 C09
resource MOTOR 4 C08
# beacon
beacon RX_LOST
beacon RX_SET
aux 0 0 0 1300 1700 0 0
aux 1 1 3 1300 1700 0 0
aux 2 2 3 1700 2100 0 0
aux 3 13 1 1300 1700 0 0
aux 4 35 2 1300 1700 0 0
# master
set gyro_lowpass2_hz = 500
set dyn_notch_q = 250
set dyn_notch_min_hz = 90
set dyn_notch_max_hz = 350
set dyn_lpf_gyro_min_hz = 400
set dyn_lpf_gyro_max_hz = 1000
set acc_calibration = -78,-26,-21,1
set mag_hardware = NONE
set dshot_idle_value = 300
set dshot_bidir = ON
set beeper_dshot_beacon_tone = 3
set yaw_motors_reversed = ON
set small_angle = 180
set pid_process_denom = 2
set debug_mode = GYRO_SCALED
set gyro_1_align_yaw = 1800
set name = HD1 w/ Vanny arm
# profile 0
set dyn_lpf_dterm_min_hz = 126
set dyn_lpf_dterm_max_hz = 306
set dterm_lowpass2_hz = 270
set vbat_pid_gain = ON
set feedforward_transition = 5
set iterm_relax_cutoff = 10
set yaw_lowpass_hz = 100
set p_pitch = 55
set d_pitch = 35
set f_pitch = 143
set p_roll = 50
set d_roll = 32
set f_roll = 135
set p_yaw = 54
set f_yaw = 135
set d_min_roll = 0
set d_min_pitch = 0
set idle_min_rpm = 15
profile 1
profile 2
# rateprofile 0
set roll_rc_rate = 155
set pitch_rc_rate = 155
set roll_expo = 20
set pitch_expo = 20
set yaw_expo = 20
set roll_srate = 69
set pitch_srate = 69
rateprofile 1
rateprofile 2
rateprofile 3
rateprofile 4
rateprofile 5
# save configuration
save
A video I think would be very helpful.
(20-Nov-2021, 05:21 PM)the.ronin Wrote: A video I think would be very helpful.
Hello Ronin,
Thank you for the reply. I've uploaded the video to youtube. I'm not sure about uploading video here as I don't know if we can. the video is short bout 30'
https://youtu.be/1qkoOPAGeTo
Thank you
I'm not sure I see (or hear) what the problem is. That motor noise is normal when doing flips or rolls - admittedly some of those flips do sound different but not really alarmingly different. As for the overshoot I saw one time where it looked like you might have over-rotated resulting in more forward pitch making the quad shoot out. Your PIDs also look reasonable (5S I assume based on your D's) as well as the P/D relationship.
If I was forced to highlight something then it might be your feed forwards at 143/135 - you could just try zero'ing that out but honestly even 145/135 is perfectly reasonable. I'll run 200 if the blackbox traces say there's room.
Did your flips feel and sound different on other quads? Did you keep the same rates?
  Quad turing green Scro 7 280 17-May-2024, 07:27 PM
Last Post: peveleigh
  Need advice getting back into building quadcopters Radworm 169 5,031 24-Apr-2024, 07:00 PM
Last Post: SeismicCWave
  Need help with quad drifting…. danny 20 1,373 06-Apr-2024, 04:53 PM
Last Post: infrared4ever
  Anyone ever X-Ray a quad? Rob Axel 0 135 18-Mar-2024, 06:54 PM
  Where do I start PID tuning this quad? relentlesstech 15 626 17-Mar-2024, 05:22 PM
