I've jumped through a hoops for a bit now trying to find decent documentation on all this, but so far i've yet to have any luck.
I have maanged to-
1. Connect the meteor65 to betaflight. I saved the initial setup. From what I can tell the relevant dropdown is the channel map, which is currently set to TAER1234. This is from the "spektrum" setting, but I can also choose Frsky (AETR1234) and default (Same thing).
2. Connect the controller to OpenTX. From there i didn't do much, but I did note that the default seems to be TAER...however i'm not sure what mode its in.
The documentation is sparse to say the least, and also seems to be out of date. I attempted pushing the bind button on the back of the transmitter and then on the flight board (with the battery in), but it doesn't seem to do anything (and is tricky to do in time). Lots of stuff mentions a flashing green LED, but mine is blue instead...?
I can't find any real examples of someone binding this, as most of what i find just seems to assume you know how to do it, or is for a vastly different transmitter which makes me think i'm missing something.
Oh and before i forget the LiteRadio instructions do mention switching protocol by holding the Bind button and then "pressing" the power button until the purple light is flashing and then counting the number of flashes to determine what mode you're in. I can't get this to work at all, trying different combinations of press/hold.
Edit-
Still can't get it, but found a few more things-
1. I may have been looking at the wrong betaflight setting? I found the reciever section under configuration. It's set on serial-based receiver with CRSF as the provider, however I can't seem to change it, as save and reboot just reboots with the same setting?
2. There is another button on the underside of the whoop that does trigger a green LED, however I think this is connected to the camera. The red/blue LED's button has the letters PNP above it, the red/green, nano. Of note the red/green seems to be on a totally different chip which is sitting below the board/above the battery holder.
Edit 2-
I believe the mistake was made when ordering. Looking at the drone I think this is a TBS crossfire version, not the FrSky...which would explain the inability to pair. Not sure how to even proceed from here. I guess I either get a new transmitter or swap the receiver. Both seem much heavier than I was hoping for a first try though.
I have maanged to-
Edit-
Edit 2-
