29-Aug-2021, 04:50 PM
I have a hobbywing 40amp and 60amp 4n1.
I have some BH 2507 1750 motors I was going to use with 4S and 7” props.
I probably should play it safe and use 60amp but I don’t think the motors will pull over 30amps each so I am considering using the 20 by 20 40amp.
I have a 2506 1845Kv and on 4S it pulls 26amps with 7 by 5 prop so I don’t think 2507 1750 will pull over 30amps but it’s a 12 ounce fixed wing.It has a 60amp burst rate.
Honestly I just want to try out the lighter 20 by 20 40amp 4n1.It’s something different.
Anyway I thought I’d ask if I could use the 40amp and not see it come down toast.
