calling blackbox ninjas
5" quad loss of control after flips and rolls Best example 0.32sec into flight. dont know how to diagnose the issue and i was hoping to do it with blackbox
 *It's a readytosky kt230 frame running 6s, 1999kv iflight cyber  motors, 45a singles iflight esc, matek f722se.  ~650g all up weight
  *-*after flip or roll my motors heat up by about 5 C untill the esc's are overtemp all the way to almost burning them without temp protection in bl_heli.
- same quad flew great with temps around 60-70 no higher than 80 C after the hardest flying before last crash
-It almost seems like a desync but I cant diagnose the problem and not sure where to look.
-thinking bad motor or esc
-also thinking maybe bad cap sending voltage spikes...
- Everything on the quad "looks" good i.e. no broken arms or frayed loose wires I can see no evidence of burnt ESC or motors everything is tight, soft mounted, and lock-tighted
- ESC settings I changed are
 * demag comp- high
 * rampup power- 12%
 * Auto timing/also tried 23deg no differance
 * Variable PWM 16-48hz also tried 24hz locked no change
 * temp protection 90 C
-link to flight video, cli dump, bbl, and goggle DVR
https://drive.google.com/.../1hATihPUqzopvpFN6Izd9iylgnuX...
  Thanks so much in advance!!!
USMC Infantry... Get some... Bent Props!?!?
Heya guys just wanted to post right quick I think I fixed the issue... changed ESC #3 and everything seems kosher! even went back to my tune with no gyro lowpasses and some pretty high d for a near-perfect step response! flies like a homing missile!
also, i got some suggestions to change the ESC settings away from auto timing and PWM but everything is back and flying great
Great ! to hear!
how do you come to the solution of swapping esc#3
I only know that i know nothing
  Help Openlog Blackbox on Tyro79 Corrado-c 18 4,471 16-Oct-2022, 10:33 AM
Last Post: kvark85
  Blackbox examples Major Tom 0 371 22-Nov-2021, 01:40 PM
Last Post: Major Tom
  I'm calling this one the Radnoceros-X RENOV8R 45 4,229 22-May-2018, 07:40 PM
Last Post: Krohsis
