Hi all!
This is my first post here, but I've been reading this forum for a month now and I found it really nice!
I'm really new to FPV (actually I didn't even start with the real thing
After reading many people's opinions, I decided to buy a controller and play simulators for a while, so that I could understand when to buy a BNF drone (and which one).
Since I didn't know if I was going to like it, I decided to make some compromises and I choose to buy the Jumper T-Pro and DRL sim.
I've been playing for few days now and I'm liking it a lot!
But today I had a problem. while using the throttle, I noticed that my drone was having a little bit of yaw.
I checked the signal going to the computer and when I move straight up the throttle there is a peak on the yaw channel (to the right) around mid-range, even though the gimbal is perfectly centered. I noticed it in EdgeTx as well, so I thought I might need to calibrate (I never did it before).
The result was a disaster, because this "fake" yaw peak sums up to the actual movement so I can yaw to the right just a bit and when I use the throttle the drone turns to the right.
I looked up in the forum and I didn't find anything…
This is the video of the output I get when moving the throttle (throttle is axis 2, yaw axis 3):
Can somebody help me, please?
Thank you!
p.s. I'm not a native english speaker, so I hope you can understand…
![Big Grin Big Grin](https://intofpv.com/images/smilies/biggrin.png)
Thank you!
