25-Mar-2024, 06:24 PM
Hi all,
I recently decided to get into Fpv wings after flying quadcopters for years. I picked up a Baby AR wing pro as it seemed a nice starting point size-wise. It's maiden went very well and all was well. A couple of flights (and bad landings) later, one of the elevons began to break off at the foam hinges. I don't have much experience with this EPP foam material, but I definitely knew when I was building it that those foam hinges were going to be a weak point. After some research online most solutions pointed towards some special kind of tape or hinges made from glue. None of these options enticed me as I wanted something confidently strong and something that did not look like a botched job either. As a temporary measure I simply hot-glued the fracture in the foam and continued on (pictures below). As strong as it was, it broke again from an unfortunate crash, and the repair rendered the hinges to be quite stiff, and not able to throw about half as much. Devastated about my new wing, and replacement parts being non-existent for this model, I had to do some thinking. Previously I had 3D printed a small wing model that relied on fully 3D printed elevons and hinges. So what I'm wondering is should I cut off the elevons and replace the foam hinges with a very thin slit of 3D printed plastic that would slit into the elevon and wing, or just 3D print some elevons with these slits attached and do something similar. Has anyone any experience with this type of repair job or any suggestions? TIA
Pics
Pics
