Hi - So I have been messing with this gyro over the weekend and got a good tune out of it. I figured I'd post a level flight slow throttle ramp PID toolbox spectral graph. So no flips or rolls in this flight so all you see is the motor noise across the full throttle range.
I left my PIDs on default for this, LPF1 off, LPF slider to 2.0, RPM filtering enabled, 2 dynamic notches min/max 100-400hz with a Q value of 400, and a single biquad filter on D at 101hz,
This gyro picked up 2 frame resonances that the MPU6000 never picked up before. Not really sure why. That's why I have the extra dynamic notch. The frame resonance is at a lower frequency than I'd like (136 hz) but the dynamic notch took care of it without adding hardly any delay. I did test 2 flight controllers with the same BMI270 chip and they both picked up this resonance. No one else has reported this though so it could just be my build.
Anyway - overall it flies great. I've been able to push my PIDs higher than with the MPU6000 due to the low noise between 50-200hz (with the exception of the frame resonance at 136hz). You can see a first and second harmonic in the motor noise that the RPM filter has no problem taking care of.
I'm currently running this with the above filtering with the master slider at 1.5 and even on a 90 degree day the motors aren't hot (pretty warm but not hot). I couldn't do that with the last MPU6000 I had on the same build. Also because I could get more aggressive with my filtering I have almost no propwash using Nazgul F5 5" props.
Hope that helps!
sub 100hz
Method I used is detailed in this video
