Black and white caddx ant (only on attv6)
Hello
I just stuck a caddx ant, which I have used on a few previous builds, into an 85mm whoop. On my Ev800d everything looks normal. On attv6 the image is in black and white. Anybody know what is going on here? Its flyable but annoying.
Thanks for any help,
Mr_Stripes
Are the v6 set to the correct channel? Make sure you set the channel manually, don't use auto scan.
Yes, thank you for checking.
Sounds like a PAL/NTSC issue, manually set all to the same?
[-] The following 1 user Likes Bad Raven's post:
  • Mr_Stripes
Hmm never even thought about that I will have to check, thx.
  Black video but with OSD Dexter 6 277 08-Mar-2024, 10:42 AM
Last Post: Dexter
  Black screen and no OSD: Eachine TX06 + EV800 + DarwinFPV F411 Ultralight/Whoop AIO aprudnikoff 1 202 05-Mar-2024, 09:18 PM
  Solved CADDX Ratel 2 menu not working drumgod 3 456 15-Dec-2023, 01:25 AM
Last Post: drumgod
  black screens on hdo2 :-/ hugnosed_bat 5 416 31-May-2023, 09:38 AM
  Help Caddx Turtle v2 coax cable replacement cst3x6 9 841 08-Mar-2023, 10:36 PM
Last Post: cst3x6
