Threads: 40
Likes Received: 18 in 16 posts
Likes Given: 1
1 Hello again,
My tinyhawk has suddenly stopped showing battery voltage in betaflight an in the osd. I had an issue with betaflight showing the wrong battery voltage and changed the BF/Battery setting from onboard ACDC to ESC and it worked for a few minutes and now it wont work at all. If i change it back to Onboard ACDC still no voltage reads in the BF/Battery tab. I did not change anything in the CLI os I am not sure what happened.
Thanks in advance.
Threads: 125
Likes Given: 99
388 Do you see the wrong reading where the voltage supposed to be or do you not see anything? Do you see the correct voltage in BFC? Can you post a dump file?
Threads: 40
Likes Given: 1
1 No reading at all. I can post the dump this evening.....No reading in the BFC battery tab or in the osd...
Threads: 125
Likes Given: 99
388 08-Jan-2020, 06:34 PM (This post was last modified: 08-Jan-2020, 06:41 PM by voodoo614.) I don't think the Tinkhawk ESC has telemetry. So you likely want to move it back to onboard ADC. Then we can look at why it doesn't work.
Threads: 125
Likes Given: 99
388 Your settings look good.
What voltage reading do you get in BFC when you plug in your lipo?
Threads: 40
Likes Given: 1
1 I dont get any voltage reading in bfc.
Threads: 125
Likes Given: 99
388 So, plugged into BFC, and plugged into lipo, your reading is 0.0V?
Have you tried reflashing the firmware? I would save a dump before you reflash.
Threads: 40
Likes Given: 1
1 yes, pluged into bfc and lipo pluged in I get no battery voltage in either the osd of the goggles or on the battery tab in bfc. I will try a re-flash to see if that fixes it....
Threads: 125
Likes Given: 99
388 Can you verify what Tinkhawk you have. The different quads have different firmware.
Threads: 40
Likes Given: 1
1 It is the RTF indoor one. The 1s white one.
