Betaflight F3 OSD doesn't show up in flight
Betaflight F3 FC. Question regarding the built-in OSD. I am able to see the main menu, navigate within the menus, change PIDs and vTx options as well as assign what I want to see on the screen in flight.
Despite this, why is nothing showing on the screen in flight?
Settings in Betaflight are saved and verified within the OSD itself.
1. Mismatch PAL/NTSC settings between CAM and OSD? I had to switch mine to PAL or auto before anything would show on the screen. It would get cropped out on ntsc.
2. Do you have osd switch setup in modes? If so it needs to be switched on.
(26-Apr-2017, 09:42 PM)T18099 Wrote: 1. Mismatch PAL/NTSC settings between CAM and OSD? I had to switch mine to PAL or auto before anything would show on the screen. It would get cropped out on ntsc.
FIXED: I had the OSDSW activated and assigned to a switch thinking I needed this in order for it to work.
I completely removed the OSDSW parameter in the Configuration Tab and my OSD info showed up in my goggles.
I did need to adjust the location of the info because of cropping (16:9) but the initial issue was fixed by removing the OSDSW parameter.
[-] The following 1 user Likes cche's post:
  • PaulMek
  JHEMCU GHF745 HD AIO F7 OSD Flight Controller and Built-In 40A BLHeli32 3-6S FC husafreak 0 82 05-May-2024, 01:11 AM
Last Post: husafreak
  Help No response flight controller with receiver Crazyart 1 263 09-Jan-2024, 12:53 AM
Last Post: Crazyart
  Bringing an old betaflight target into 4.4.0 husafreak 10 1,612 22-Nov-2023, 02:45 PM
  F4 1S 5A AIO FC ELRS Current Draw in OSD segler999 6 672 17-Nov-2023, 02:57 AM
Last Post: segler999
  What happens when I load a Betaflight Preset Tune in my FC? husafreak 6 526 07-Nov-2023, 02:56 AM
