13-Jan-2016, 09:16 PM
Betaflight 2.3.0 RC1 released:
-new filtering for smoother D term
-new feature insane_acro_factor, which is like Acro+ on Openpilot. I very welcome this feature! (only works with airmode on)
What do you guys think?
Copying from FB Group:
BorisB: "Added new feature set insane_acro_factor= 0-100 (0 means disabled and 100 is maximum). This is simillar to Acro+ feature, but it only works when in Air mode. This is to prevent many modes. The option will improve center stick feeling more and add more "super expo" on more stick reflection"
Basically you can set relatively low rates to fine control around midstick and also have very quick reaction at full stick, soft flying but insane fast flips and rolls.
Another experimental feature is that the FC can compensate for camera tilt angle and command the motor so that the roll stick will give you pure roll and yaw pure yaw etc.
when flying in a 30degree angle and you yaw. it will keep the horizon level. This was a feature request of someone and Boris made it real. Personally I won't activate this, i like to be in control.
