Beeper on IFlight Chimera5 LR
Hey all- I picked up the Chimera5 LR and have hit a new one.
I have everything set-up, but when I pull the battery after 30 seconds out starts to beep non-stop.
I have tried using "Beeper -All" in Betaflight and that did not seem to change anything.
Does anyone have any ideas? Is there a button somewhere I'm missing? My hunch is that it's a feature to find the drone if the battery got torn off.
Thanks,
Jake
It probably has a self-powered buzzer installed on it. If you can locate the buzzer then look for a button on it and hold it down for a few seconds. The other way to disarm some of the self-powered buzzers is to momentarily re-plug the LiPo and then unplug it again.
Found it! I figured it had to a button. I’d even been pressing it at one point but it had a lot of heat shrink on it.
Hi! I'm having the same issue right now. Where is the button located on the beeper?
It’s super hard to find it. It’s toward the back of the buzzer apparatus. It’s a tiny black button covered with shrink wrap and probably obscured by wires. I had to use one of my small allens to reach in and hold it for about 3 seconds.
I’ve since moved all the guts from that drone onto a QAV-Cine Freybot. Still dealing with it on there, but made it easier to reach.
  Beeper inop lefty 4 305 02-Jun-2024, 06:50 PM
Last Post: lefty
  Does anyone has list of 'beeper codes' (Why my drone beeps before/*after* armin alfonz19 11 402 18-May-2024, 09:17 PM
Last Post: alfonz19
  Loud Beeper BobMaine 3 232 25-Oct-2023, 11:13 AM
  help with figuring out softserial on iflight Succex-D F411 Marcelo 7 480 09-Aug-2023, 02:43 AM
Last Post: Marcelo
  iFlight Blitz aio no osd with dji o3 and BF 4.4.2 Watahboy 3 342 10-Jun-2023, 11:43 PM
Last Post: Watahboy
