12-Nov-2023, 07:17 PM
My fiancee' & I have 3 of them! Would we be able 2 use them on a fpv build? I crashed the autel evo 2 pro, & she will never fly again. So it would be great to be able to use those 3 batteries. I will haft to choose when soldering, what cells I will fly with, 3-5s or 6s LiPo . I will choose 6s if we can't use those big badboys from autel! They are in the lower end of the voltage the stack will accept. Will that be a problem??
Motors: AOS 2207 Supernova
Frame: iFLIGHT AOS 5.5" 1.2 EVO
Stack: Diatone MAMBA F722 MK4 55A 6S 32Bit 128k MPU6000 Stack
EVO II Battery Specifications
Battery type: High-Performance Li-Po Battery.
Rated Capacity: 7100mAh.
Power: 82Wh.
Nominal Voltage: 11.55V.
Is the physics possible U think? Connecting those 3S LiPo, 365 grams heavy badboys?
Casper
Power: 82Wh.
Casper
