This may be a slow build because I really have no idea what to make of this frame lol. Maybe you guys can help me out with this one.
It was more of an impulse buy seeing Armattan getting into the 4 inch micro LR trend. That and I'm a sucker for cool camera cages and custom cut lipo pads.
Total of 11 days shipping from Armattan HQ to Southern California which is pretty good all things considered ...
I'm glad frame makers are moving to chamfered edges rather than leaving us to file freshly cut carbon.
The alu parts are trademark Armattan goodness ...
Custom cut lipo pad yes please.
Even Chris admitted in a launch video that 5 screws per arm is likely overkill. I suspect he'd gotten a lot of flack from the sketchy arms loosening up on prior frames like the Badger - something I experienced myself and found so detrimental to a good tune that I switched to Apex. I was going to go with 3 screws then checking the gyro_scaled later but decided to just go with all 5.
What got me though was he left some slop in the arms lol. If you don't tighten down all the screws, there is quite a bit of wiggle. I just don't get it.
There are two sets of rear arm holes. The set closer to the middle makes it a "compressed X" configuration with a 182mm wheelbase more in line with other 4 inch micro LRs on the market. I opted for the "true X" configuration using the rear-most set of arm holes for a 200mm wheelbase. This was really more to keep the countersunk nuts from sitting right below the rear stack than for flight characteristics ...
And you are supposed to use *M6* screws for the arms for super duper Armattan secureness lawls.
Saucy ...
There's a ton of parts and doodads left in the baggie which is mostly for DJI stuffs. Otherwise ...
Mine clocks in a good 5g more than the stated 57g on the product page so not too sure whatsupwiddatyo ...
Compared to the Diatome Roma F4 ...
Compared to the Tomoquads Katana ...
Stack height looks awfully tight but it's actually the standard 20mm just like other 4 inch micro LRs ...
Space between the camera cage and the front stack is about 10mm ...
Space between stacks is about 5mm ...
Space between the rear stack and rear standoffs is about 15mm ...
I was really hoping to go whoop AIO and whoop HD cam with this one but it might be cutting it too tight unless I can find some sort of offset whoop adapter - and I'm hesitant to 3d print one for the vibrations such an adapter might introduce.
I may just go with dual 20x20s using a Kakute F7 Mini stack and a Caddx Tarsier ...
Another issue is the no standoffs. Add to that the funky shape of the rear brackets. This makes for designing antenna mounts a super pain in the ass. There are what I'm assuming are zip tie holes for a DJI unit which I might be able to use as antenna anchor mounts.
I'm also still hoping I can somehow use a whoop board with this. Hmmm ....
Saucy ...
