Threads: 49
Likes Received: 2 in 2 posts
Likes Given: 1
0 Hi all. I have a jumper t18 using OpenTX version 2.3.8. I would like to add the Amber sound pack to my transmitter. Can I just use the Amber sound pack that is for OPenTX version 2.2 or do I need the specific pack for 2.3.8. I cannot find the pack for 2.3.8 on the internet. If I need that specific one can someone link it to me? Also, I understand how to get the sounds onto my transmitter SD card (you just copy the folder into the sounds tab on my SD card) but how do I actually make the radio play the sounds when I flip a switch or do an action?
Thanks!
Threads: 587
Likes Received: 8,976 in 6,643 posts
Likes Given: 1,425
789 The sound pack is just a load of WAV files with the same names as the original WAV files, so you just replace the original files on your SD card with the Amber Sound Pack ones and they will just work.
To make the transmitter play the sounds you need to create entries in the SPECIAL FUNCTIONS page of the model to "Play Track" when something happens on the transmitter such as a switch position being changed or a telemetry value changing. You can also configure entries in the LOGICAL SWITCHES page that can be used as a trigger for a special function entry.
