Threads: 108
Likes Given: 344
3 I had a bad crash last weekend and it not only ripped the coax out of my camera, but it also ripped the cable out of the vista, with that screw-in clamp still in place. I guess in ripping it out of the vista, it broke off the front part of the black connector plug the wire clamps into...if any of this makes any sense.
So if I plug the cable back in and screw in that clamp, the cable will just slide out of the vista now. Would hot glue damage anything? I'd hate to scrap a perfectly good Vista.
Threads: 108
Likes Given: 344
3 Good point with the heat. I found neutral cure silicone - will look more into that. Thank you, Snow!
Threads: 108
Likes Given: 344
3 (22-Oct-2021, 05:22 PM)SnowLeopardFPV Wrote: Just make sure whatever you use secures the cable on really well so it's not going to go anywhere. The last thing you want is the cable vibrating loose and then popping off mid-flight
That's what worries me.
I see Bardwell recommends E6000 adhesive, I may try that. One thing is for sure - from now on I'm only using coax cables with PLENTY of slack.
Threads: 203
Likes Given: 306
11 22-Oct-2021, 06:34 PM (This post was last modified: 22-Oct-2021, 06:35 PM by Rob3ddd.) Cyclonefpv shows a repair on a Caddx vista antenna.I don’t know if it’s the same thing your needing repaired.
He has done several different repairs on the ufl in Caddx and it looks like he is doing another live at this moment.
Threads: 108
Likes Given: 344
3 (22-Oct-2021, 06:34 PM)Rob3ddd Wrote: Cyclonefpv shows a repair on a Caddx vista antenna.I don’t know if it’s the same thing your needing repaired.
That's the u.fl connector - I've replaced plenty of those but thanks
What I'm referring to is what the camera cable plugs into - I saw Snow once referred to it as the MIPI connector...?
Threads: 108
Likes Given: 344
3 22-Oct-2021, 07:22 PM Proud team pilot for brands I love: Dquad - Happymodel - Gemfan
