07-Jan-2022, 02:21 PM
Hi everyone,
I'm building a new quadcopter with some older parts I had lying arround. It's my second build so I'm quite new.
I'm up to this point:
I'm using an Aikon F4 FC (43030 V1.2) and an FrSky R-XSR (already used in my previous quadcopter).
TX and RX are bound and both updated to the latest firmware.
FC is running the latest Betaflight firmware.
- First I tried to connect the receiver SBUS to the UART1 pad and Smartport to the UART3 (TELE) pad: no receiver connection and no telemetry.
- I messed a bit around with the CLI (serialrx_inverted = ON, tlm_inverted = ON, tlm_halfduplex = OFF): no improvement.
I know that FrSky receivers use inverted signals but I'm not sure if the FC has a build in inverter on UART1 or how the Betaflight commands (serialrx_inverted) work/react on this. I already tried the uninverted pads from the R-XSR on UART1 and UART3 but no success either...
Current situation:
I connected the receiver SBUS tot UART3 pad because I figured from the manual this port has a bidirectional inverter: Now my receiver has connection (checked in Betaflight).
I connected the Smartport to the RX4 pad which is a Softserial and tried to get the telemetry working but still no succes.
So I'm up to the point I don't got my Telemetry working.
Can anyone help me with this? Or should I just leave this and use my OSD for telemetry? Like I already mentioned, I'm quite new
The manual is rather brief and the Github page doesn't hold much information (it's btw for version 1.1 which is slightely different).
Here is my cli diff output:
Ports tab in Betaflight:
Current situation:
diff
# Betaflight / STM32F405 (S405) 4.2.9 Apr 27 2021 / 19:33:01 (e097f4ab7) MSP API: 1.43
# config: manufacturer_id: AIKO, board_name: AIKONF4, version: 3a35e73b, date: 2019-09-30T05:46:12Z
# start the command batch
batch start
board_name AIKONF4
manufacturer_id AIKO
# name: Jonaikon
feature -AIRMODE
feature RX_SERIAL
feature SOFTSERIAL
feature TELEMETRY
# map
map TAER1234
serial 0 32 115200 57600 0 115200
# master
set acc_calibration = -76,-15,-17,1
set serialrx_provider = SBUS
set serialrx_inverted = ON
set tlm_inverted = ON
set tlm_halfduplex = OFF
set name = Jonaikon
# end the command batch
batch end
