30-Sep-2019, 09:28 AM
Hey everyone.
I successfully flashed my aio whoop board from namelessrc from 4.0.x to 3.5.7 and now I can’t connect in normal mode.
I downgraded to get smart audio working on an AKK nano vtx that only works with smart audio. I’ve had this problem before when bf 4.0.x had a different smart Audi to bf 3.5.x. In the past I have downgraded and got the vtx to work.
In this case the target for the namelessrc aio whoop board is matekf411.
I launch the board in boot mode and can flash the board ok. Remove power and connect USB again and it won’t connect in regular mode to configure it.
I used zadig to get it going in boot mode but it only worked when I pressed the boot button at power on. Other fc boards haves worked in the past by just typing BL in the cli and it has entered the mode ok.
My thought is that I’ve screwed up the usb driver connection by loading zadig and stm etc.
Is there anything anyone recommends I do to clean up my software install to be able to connect again to the namelessrc aio whoop board?
I had it working ok before the downgrade to 3.5.7 and configured it and all was ok, modes, serial rx, everything ok - I just wanted to get smart audio going for the Vtx.
Any suggestions? Sorry for the ramble.
Cheers,
ph2t.
Cheers,
ph2t.
