01-Jun-2021, 08:59 PM
Hi folks,
In the not-too-distant past, I used a larger drone with a Pixhawk flight controller. It was configured so that I had a switch on my Taranis that could put it in remove control mode ('stabilized' mode in ArduCopter, I think; but at any rate controlled with the joysticks), or put it in autonomy control ('guided' mode in Arducopter; it would receive waypoints or commands via MAVlink over a serial port connected to an onboard computer).
iNav appears to have some of the same basic functionality, but I can't quite parse the docs to figure out if I can do something similar. Is it theoretically possible?
If the iNav system can do this (allow waypoint injection or remote control), can the smaller boards like are on the Flywoo Firefly support this (do they have a spare serial port for input/output, via Mavlink or something else)?
Any thoughts or manual references appreciated.....
